Rotor rust
Old Oct 10, 2025 | 05:49 AM
Brookspw's Avatar
Brookspw
Default Rotor rust
Have a 25 with the glossy wheels. Every time I wash my car the rotors have a layer of rust as they dry. Drive the car and the rust dust is all over the wheels. Not brake dust. Any solutions?
Old Oct 10, 2025 | 06:40 AM
KennyFSU's Avatar
KennyFSU
That is fairly common in all the cars I've owned.
My RC was no different so when it was time, I replaced them with Dynamic Friction rotors that were "Geospec coated" and they still look great after a year.
Old Oct 10, 2025 | 06:42 AM
95bat's Avatar
95bat
Nope. Coated rotors help the vanes to stop the rust, but surface rust will likely continue. It's a big iron disc with water on it, science happens lol
You can do the RCF carbon ceramic brake setup No metal, no rust!
Old Oct 10, 2025 | 08:26 AM
Benibiker1558's Avatar
Benibiker1558
Even worse is when the pads lock on to the rotor after a wash so when you drive off the first time after, there's a loud bang as the brakes unseize. It happens when I wash it at home and there's no distance to heat up and dry the brakes.
Old Oct 10, 2025 | 09:00 AM
SlowlaneAZ's Avatar
SlowlaneAZ
Its flash rust from water. Its common. It goes away after you drive the car and use the brakes. I normally take some compressed air to blow the rust off the wheels.
Old Oct 10, 2025 | 10:58 AM
arentz07's Avatar
arentz07
Yeah this is totally normal; happens on both my IS 500 and the wife's X3 whenever I hand-wash them because I park them shortly after, which allows rust to form on the wet rotors.
Old Oct 10, 2025 | 11:58 AM
95bat's Avatar
95bat
I try to turn OFF the parking brake after I wash so that doesn't happen Just that first park in the garage.
Old Oct 10, 2025 | 04:15 PM
Benibiker1558
I've tried that and it still does it but not as bad. The only other cars I've had that did that were my Minis .
Old Oct 12, 2025 | 03:43 PM
InveredMP's Avatar
InveredMP
I forget, then crap my pants. Every. Single. Time.
Old Oct 12, 2025 | 04:01 PM
TEXASLEXUS's Avatar
TEXASLEXUS
happened to me this morning, drove around a little bit and the rust disappeared lol.
ColdFusion
Oct 13, 2025 04:43 AM
mikersoft
IS F (2008-2014)
Jun 20, 2016 04:34 AM
detailersdomain
Automotive Care & Detailing
Jul 20, 2013 04:47 PM
Hopeful
Maintenance
12
Apr 19, 2004 10:12 PM
chanman
Suspension and Brakes
Sep 21, 2001 05:48 PM
