TPMS woes
Old Nov 2, 2021 | 06:04 PM
wthrman2's Avatar
wthrman2
Originally Posted by right360
I spoke too soon. Just got back in the car and the dashes are back ;(
That sucks - I hope that you can find a solution to this mystery but you would think it's not rocket science and TPMS should be easy to reprogram or something. I have to ask though, did you check if the tech drank his beer already? You could retrieve it.... J/K
Old Nov 17, 2021 | 06:00 PM
right360's Avatar
right360
There's a happy ending to the story — a local Lexus/Toyota specialist identified a sensor that needed to be changed. I don't know whether it was damaged during the tire change at Costco or battery was dying, but a new Denso unit fixed the issue.
Old Nov 17, 2021 | 06:09 PM
wthrman2's Avatar
wthrman2
Thanks for the update - So many people come here for help and then never come back and give us closure so much appreciated, and happy you got a good outcome
Old Nov 18, 2021 | 05:08 AM
Sasnuke's Avatar
Sasnuke
Thanks for reporting back.
I would still bet money it was the battery.
The sensors only job is to transmit information to the vehicle...when it stops doing that, then it's no longer of any use.
The simplest explanation of why it would stop doing that is the battery dying.
Consider that all the sensors were put in the vehicle at the same time, so if the battery was low on this one, it wouldn't be unreasonable that the remainder will be getting low as well.
Realistically one sensor is going to be low first, and another last, with the other two in between somewhere. Just something to consider if the issue returns in the next 3-12 months.
JakeMan324
May 10, 2021 07:09 AM
IntrinoX
Jan 10, 2021 09:42 AM
Scottehboy
Aug 19, 2020 10:19 AM
larrytstar
Aug 14, 2019 09:14 PM
Myrix
Wheels, Tires & Brakes Forum
Jul 5, 2016 08:59 PM
