reduce engine power
Old Oct 10, 2021 | 05:13 PM
alzaabi's Avatar
alzaabi
Angry reduce engine power
moorning ,
since month i face that issue " reduce engine power " and i went to check and i found : charge air cooler temperature sensor !
the power is reduce too much and turbo also reduce if i bush from zero !
also i search about this sensor but i not found any thing about it !
Old Oct 11, 2021 | 04:51 PM
Sasnuke's Avatar
Sasnuke
Welcome to the forum!
Below is a pic of where the sensor is located. I suggest first confirm it is plugged in and the connector/wires are not damaged.
Old Oct 14, 2021 | 03:47 AM
alzaabi's Avatar
alzaabi
Smile
thank you mr.Sasuke for your reply
i disconnect and i see the turbo gauge off and the pointer in red zone " No safety "
also check engine not working during i disconnect this sensor
i think i have issue in car electricity
Old Oct 14, 2021 | 04:40 AM
Sasnuke's Avatar
Sasnuke
If you disconnected the sensor and the car reacted by turning the turbo gauge off and the pointer went into the red zone "No Safety", then I suspect the car's electrical system is fine.
The check engine light not coming on might be okay...sometimes the computer has to see the error on at least two drive cycles before it triggers the light.
Without further testing that would require a Techstream, I would suggest replacing the sensor.
Old Oct 14, 2021 | 04:44 AM
alzaabi's Avatar
alzaabi
first i will replace sensor it's not difficult
i hope the issue from sensor
regards,
L3xusGX
GX - 2nd Gen (2010-2023)
May 6, 2021 04:37 AM
JesLet
Maintenance
Nov 13, 2013 07:02 AM
turbo80
Aug 17, 2011 11:24 AM
Jeff92se
Hybrid Technology
Feb 18, 2011 05:24 AM
SteVTEC
Apr 16, 2006 06:57 AM
