Base IS take grille removal
Old Jul 26, 2021 | 12:11 PM
zhifan1's Avatar
zhifan1
Default Base IS take grille removal
I have a base IS 200t and am wondering whether the grille (top and bottom) part can be removed without removing the whole bumper? Is there a step by step if anyone done it? Thx.
Old Jul 26, 2021 | 12:30 PM
whoismiked's Avatar
whoismiked
The bumper must be removed in order to remove the grill
Old Jul 27, 2021 | 09:10 AM
chinox22x's Avatar
chinox22x
yup, there’s a bunch of small screws
Old Jul 27, 2021 | 12:49 PM
whoismiked's Avatar
whoismiked
I can tell you from experience that the front bumper is actually fairly easy to remove.
Removing the grill from the bumper (once it's off) is actually more of a pain in the a** than removing the bumper lol
What are you trying to do with your grill? I may have some suggestion based on what you are trying to do
Here's a video on how to remove the bumper though
Old Jul 27, 2021 | 12:52 PM
zhifan1's Avatar
zhifan1
https://www.youtube.com/watch?v=4Gps3vuTIDA
Just had an idea to DIY wrap the grille totally matte black or some other black to match the color of the car and the chrome parts as well. Thought it would be an easy dismantle…
Old Jul 27, 2021 | 01:09 PM
whoismiked's Avatar
whoismiked
Well in that case, I may be able to help without removing the grill.
Are you committed to it being wrapped, or would you be okay painting it? I tried to wrap mine, and I am pretty good at wrapping parts as I have done a lot of wraps on a lot of different things, but that front grill and chrome trim, even with the bumper off was a royal pain in the a** and I ending up removing it as it was not perfect. So I decided to just paint it.
If your are okay with painting it, like I did: here's my advice:
I did not remove the bumper (trust me I thought about it , but while the front entire bumper is easy to remove, the grill insert is a royal pain to get out, so way too much work and chance to break something.
I just masked it all off and spray painted it. It actually very easy to mask off with a little time and patience.
All you need is the following:
Masking paper:
https://www.amazon.com/Brown-Kraft-P.../dp/B082KHMC2Z https://www.amazon.com/Brown-Kraft-P.../dp/B082KHMC2Z
Blue Painters Tape:
Amazon Amazon
For paint you want you want a primer + paint, I used a primer + paint in one and it came out perfect
This is what I used for flat black:
Amazon Amazon
For gloss black, I'd use this:
https://www.amazon.com/Rust-Oleum-24.../dp/B002BWOS6C https://www.amazon.com/Rust-Oleum-24.../dp/B002BWOS6C
__________________
Wish I took a pic when I had it masked up, but didnt. The paper is what you cover almost everything with, and the painters tape is just to hold and paper in place but also the tape is handy to make of little tight corners
Read the directions on the spay pain can carefully and do not rush the process. you will want to do a very light coat for the first coat, let it dry for at least 30 minutes, then apply another coat and dry for 30 mins. I did 3 coats and it came out absolutely perfect!
I only did my chrome trim, thus I masked off the grill with the paper, but if you want to paint the grill also, just raise your hood and put a tarp or more of that masking paper behind the grill so you don't spray your radiator
Mine came out perfect and has held up for almost 2 years now with zero signs of wear
Old Jul 27, 2021 | 01:16 PM
zhifan1's Avatar
zhifan1
Masking paper: https://www.amazon.com/Brown-Kraft-P.../dp/B082KHMC2Z
Blue Painters Tape: https://www.amazon.com/gp/product/B000BQRP9W
https://www.amazon.com/gp/product/B002BWOS7Q
__________________
Initially thought about spray painting it but thought there might be paint adherence issues on those smooth glossy surface. Now with your suggestions, that is something to re-visit again. Your grille looks gorgeous! What did you do to the Lexus badge?
Old Jul 27, 2021 | 03:29 PM
whoismiked's Avatar
whoismiked
Thanks!
My Lexus emblem is actually a swap, It came from a Lexus GX 460 SUV, I liked it because it was an actual 3d looking emblem rather than the one encased in resin that comes in our car, and it has a cool honeycomb background, then I just taped off the honeycomb part and painted the 'L' and ring around the border in gloss black
It looked like this before I painted it:
Meurz
IS F (2008-2014)
12
Apr 28, 2022 06:39 AM
Yellow91
Aug 25, 2015 09:27 PM
GreatJason
Sep 20, 2013 04:36 PM
blue06gs
Jul 23, 2007 07:48 AM
indypwr
GS - 1st Gen (1993-1997)
14
May 15, 2003 01:09 AM
