Constant Wind Noise on Freeway
Old Jul 26, 2021 | 09:27 AM
Stupefyer's Avatar
Stupefyer
Default Constant Wind Noise on Freeway
Hello All,
Just wanted to see if anyone else has had this issue before but on my IS 200T, there is a consistent high pitched wind noise whenever I am on the freeway. It's as if one of my windows is slightly cracked open. I figured its got to be a seal issue so I am curious if there are any common seals that tend to fail on this vehicle. Any other tips would be helpful!
Old Jul 26, 2021 | 10:31 AM
E46CT's Avatar
E46CT
You'd have to closely examine every seal and make sure your door doesn't need adjustment (check panel gaps w/ adjacent panels). If needed you can pull the door in.
If you don't know what to look for, it may be a challenge to help you. Just make sure you don't have crooked seals, missing seals, damaged seals etc. Check window tracks/channels as well for any pinches, debris or other stuff. Everything must be clean and immaculate.
Old Jul 26, 2021 | 09:07 PM
Stupefyer's Avatar
Stupefyer
Thanks for that. Going to to fully look over the car tomorrow and see. It does not really bother me because I usually have music blasting enough to drown own the noise but whenever I have passengers in the car and have the music down cause were all talking, it gets annoying lol.
Old Jul 27, 2021 | 01:49 AM
ex00's Avatar
ex00
You can also lube the seals where the windows seal up to at the top channels. Just put some grease or WD-40 on a cloth/towel and wipe on the edge of the windows. I would also look into getting those GS weather strips between the drivers and passenger doors.
jennypenny
Nov 19, 2021 05:30 AM
Tmymck
NX - 1st Gen (2015-2021)
Apr 24, 2017 10:42 AM
nyr726
RX - 4th Gen (2016-2022)
Aug 3, 2016 10:33 AM
SeattleGS400
Jul 2, 2012 05:26 PM
PhilipMSPT
Apr 28, 2009 08:47 PM
