2021 IS With Wheel Spacers?
Old Jun 24, 2023 | 02:26 PM
  #46
Kniru's Avatar
Kniru
7th Gear
Originally Posted by PeterRC350
hey what’s up, when you get the spacers you need to use a different set of bolts than the factory ones because they’re not long enough. You need 14.5 x 45mm bolts and there’s 2 types.. ball seat and conical. If you’re gonna use the oem wheels go with ball seat.
So is this technically considered an extended wheel stud? Or are they two completely separate things. I apologize if its a dumb question as this is going to be the first modification so I just want to be clear before I start anything.
Old Jun 24, 2023 | 02:28 PM
  #47
PeterRC350's Avatar
PeterRC350
It’s not a stud, it’s a bolt.. Lexus doesn’t use lug nuts on the wheels for the new IS, they’re bolts now like European cars which makes things way easier. And no worries, no such thing as a dumb question.
Old Jun 24, 2023 | 02:43 PM
  #48
Kniru's Avatar
Kniru
7th Gear
Alright, so the bolt is what is used to bolt the wheel on, and due to the spacers, we would need longer ones to compensate for the extra space?
And the stud is completely different. Would we need extended studs though? Or is this just as simple as removing the wheels, putting the spacers on, and putting the wheels back in. Because I see videos of other people using extended wheel studs and removing the brake caliper and rotor.
Old Jun 24, 2023 | 02:46 PM
  #49
PeterRC350's Avatar
PeterRC350
Yes, all you need to do is to remove the wheel, put the spacer in place and bolt the wheel back on with the new bolts. Those spacers you’re talking about is because those cars normally use studs. But with bolts like the new IS is much more simple.
Old Jun 24, 2023 | 02:52 PM
  #50
Kniru's Avatar
Kniru
7th Gear
Okok sounds good, and yeah that makes sense, all the videos I've watched were all on different cars and had no mentions of bolts. Thanks for clarifying everything as yeah this is my first time doing any modification to any car. Definitely saved me from making the wrong judgements.
Old Feb 27, 2025 | 08:52 AM
  #51
Takyawn's Avatar
Takyawn
2nd gear
No rubbing or any issues whatsoever
I ordered them here and picked a set of 15mm and a set of 20mm:
https://shop.redline360.com/products...39596213010512
and I got the bolts from here: 16 in total
https://www.ecstuning.com/b-h-and-r-.../1454502sw~hr/
and then the locks
McGard 28317 Black Bolt Style... https://www.amazon.com/dp/B00MV9OG2G...p_mob_ap_share
Hey I’m planning on installing the same size mm Spacers from ******.
Link: https://www.ebay.com/itm/16622031327...mis&media=COPY
It comes with the extended bolts, but how did you find out which wheel locks set would work with the spacers? thanks in advance.
Old Feb 27, 2025 | 10:47 AM
  #52
PeterRC350's Avatar
PeterRC350
I am not sure how to answer your question.. are you asking me what my steps were to figure it out as in the math involved? Or do you want the link to the wheel locks?
Gumart1
Mar 12, 2021 02:06 PM
DougJoseph
Dec 10, 2012 12:04 PM
dw8787
Feb 24, 2009 05:32 AM
Bullskim
Sep 19, 2008 05:15 PM
3rdelement
Feb 25, 2006 10:18 AM
