I currently have a 2014 is 250awd @64k miles and got it when it first came out. I just did my 70k oil change and now lexus is saying these are some of the things that are needed to be done. The cabin filter and engine filter i can do myself. Im going to change my brakes soon also so the brake flush will be done. My biggest concern is the fuel injection and throttle body service. None of my friends can figure out why this needs to be done. Any suggestions? below are the prices from lexus for the services.
I'd say skip the fuel inector cleaning. I highly doubt they're going to do more than run a bottle of injector cleaner through the system and of course clean the throttle body. You can pick that up from an auto parts store for cheap.
Surprisingly, at my last service, they offered to do the same injector cleaning and throttle body service for only $153...
If you did the complete 60K service all those things should have fall under that service. Its the biggest service mark on these cars.
For all that would like the info on the 350 rwd so add the front diff for the awd for the respective service windows.
60,000 Miles or 72 Months Recommended Service
Check Installation Of Driver's Floor Mat
Reset Oil Maintenance Reminder, if Oil was Changed
Perform Road-Test on Vehicle
Rotate Tires(1)
Inspect Axle Shaft Boots
Inspect Body
Inspect Visually, Brake Linings/Drums And Brake Pads/Discs
Inspect Wiper Blades
Inspect /Adjust All Fluid Levels(2)
Inspect Ball Joints And Dust Covers
Inspect Brake Lines And Hoses
Inspect Engine Coolant
Inspect Steering Linkage And Boots
Inspect Brake Linings/Drums And Brake Pads/Discs(3)
Inspect Exhaust Pipes And Mountings
Inspect Steering Gear Box/Rack And Pinion
Inspect Drive Belts
Inspect Fuel Lines And Connections, Fuel Tank Band And Fuel Tank
Vapor Vent System Hoses
Inspect Fuel Tank Cap Gasket
Replace Brake Fluid
Replace Smart Key Battery
Replace Engine Oil And Oil Filter(4)
Replace Rear Differential Oil(5)
Replace Spark Plugs(6)
Replace Engine Air Filter
Replace Cabin Air Filter (If Equipped)
Visually Inspect Transmission for Signs of Leakage
Replace the oil filter and drain and refill the engine oil at specified intervals.
SAE 0W-20 oil is the best choice for good fuel economy and good starting
in cold weather. If SAE 0W-20 is not available, SAE 5W-20 may be used;
however, it must be replaced with SAE 0W-20 at the next oil change.
65,000 Miles or 78 Months Recommended Service
Rotate Tires(1)
If 0W-20 oil WAS NOT used at the last oil change, or if you drive primarily
under certain special operating conditions, you should also replace engine
oil with 0W-20 oil and replace the oil filter. Some conditions require
additional maintenance.
Special Operating Conditions (3)
Driving on dirt roads or on dusty roads
Inspect Engine Air Filter
Torque Nuts And Bolts On Chassis And Body
70,000 Miles or 84 Months Recommended Service
Rotate Tires(1)
75,000 Miles or 90 Months Recommended Service
Rotate Tires(1)
Inspect Body
Inspect Rear Differential Oil
Inspect Drive Belts
80,000 Miles or 96 Months Recommended Service
Rotate Tires(1)
Special Operating Conditions (5)
85,000 Miles or 102 Months Recommended Service
Rotate Tires(1)
Thank you
cabin and engine air filter can be bought for around $50 and installed in 5 minutes yourself.
brake flush for $160 is a lot, my Lexus dealer charges 120$, independent mechanic more like $80...
front and rear diff are easier than a oil change, buy the fluid yourself and pay a mechanic 30 min of labor to change them.
I did fuel injection and throttle body service for $80 from a licensed independent Toyota mechanic, they hook up a pressurized can of cleaner and run it through the system, I watched it. Toyota tech stream is used as you shut off/control certain fuel injectors during the process, it sounds cool to listen to... $299 from dealer is insane, it’s a 1 hour job taking your time.
Thank you
Important things you need to do is , Transmission fluid and Front/Rear Differential flush
Cabin and Engine air filter also but not that important, why brake fluid flush at that Mile ? Too soon to service Fuel injection and Throttle body , if you fill Top tier gas ignore the Fuel injector service , buy a bottle of Throttle body clean at American/Canadian tire and spray it but Never Touch the Valve Open/Close.
There is reason i always suggest to use Top tier gas Synthetic Engine Oil and OEM Lexus Gear oil, Air Filter, Spark Plugs etc.
Do you guys have any recommendations where i should buy the brake pads and filters? I was going to go to lexus for oem parts. Thank you to everyone for the advice btw.
RockAuto.com, eBay, Amazon.
You can buy genuine Toyota oem parts on eBay for a fraction of the price of dealer.
