Tune up question?
Old Oct 29, 2012 | 04:18 PM
Kanderson1's Avatar
Kanderson1
Default Tune up question?
Forum....i just tuned up my 95 LS400. New plugs, cable, caps and rotors. Car now starts a little quicker and accelerates a little better, but now as good as I know it could. It now sputters and pop a little as I drive it. My next move is to Seafoam it, change my coolent temperature sensor and fuel filter. Am I on the right track, what else could be giving me power issues?
Old Oct 29, 2012 | 04:28 PM
SpencerT's Avatar
SpencerT
You could clean your throttle body. That would help with the idle
Old Oct 29, 2012 | 05:54 PM
Kanderson1's Avatar
Kanderson1
How do you clean the throttle body?
Old Oct 29, 2012 | 09:55 PM
hotdawwg's Avatar
hotdawwg
Check this out!
http://www.lexls.com/tutorials/EFI/throttlebody.html
Old Oct 29, 2012 | 10:22 PM
Dranom's Avatar
Dranom
did you also changed the air filter?
Old Oct 30, 2012 | 05:44 AM
johnnyg66's Avatar
johnnyg66
I would probably hold off on the fuel filter. Just use some good fuel cleaner additive or take it to have fuel system cleaned. Seafoam is ok but you might need something stronger.
Old Oct 30, 2012 | 06:59 AM
steve2006's Avatar
steve2006
Rewind a little here, was it spluttering and popping a little before you did the tune up?
If it wasn't then I would be going back over the work done before looking any further.
Were all the leads,plugs etc all OEM specification, there have been cases where cheap parts have caused problems.
Old Oct 30, 2012 | 08:50 AM
Kanderson1's Avatar
Kanderson1
I am about to change the air filter, cabin filter and,seafoam it. In the very near, get my ecu caps redone.
Old Oct 31, 2012 | 07:18 PM
LScowboyLS's Avatar
LScowboyLS
yes, clean throttle body/butterfly, replace coolant temp sensor with the real Toyota dealership part (should be around $55 if you got the right one) and do the ECU caps - the problem is not the fuel filter or air filer or cabin filter - you might also want to spray off your MAF sensor with CRC MAF sensor cleaner but do not physically touch it with anything.
of all the things you have already done, and all the things I suggested, the single thing that made the biggest power difference in my 96 was doing the ECU caps!
giolex300
Apr 12, 2012 10:56 AM
Kbueno
Nov 25, 2011 09:06 AM
randomjoe
Sep 9, 2009 10:39 PM
daven3
Apr 15, 2004 10:36 PM
Slexus
Maintenance
Jun 2, 2003 06:22 AM
