Low beams on and off
Old Apr 5, 2019 | 09:37 AM
spindos's Avatar
spindos
Default Low beams on and off
If I'm correct, the 2016s still use HIDs for the headlight low beams. People who park in dark garages who have the automatic setting for headlights will have their lights turn on and off frequently for short amounts of time. Doesn't that significantly reduce the life of the low beams?
Old Apr 5, 2019 | 09:51 AM
dojoman's Avatar
dojoman
It sure does reduce the life of HID bulbs but F-sport comes with LED headlights standard.
Old Apr 5, 2019 | 10:31 AM
spindos's Avatar
spindos
Thanks for clarifying. With that said, how bad is it for our LED low beams to be turned on and off so frequently for short amounts of time?
Old Apr 5, 2019 | 11:04 AM
arentz07's Avatar
arentz07
LEDs will not be affected by turning on and off.
https://www.energy.gov/energysaver/s...rn-your-lights
The important part:
The operating life of a light emitting diode (LED) is unaffected by turning it on and off. While lifetime is reduced for fluorescent lamps the more often they are switched on and off, there is no negative effect on LED lifetime. This characteristic gives LEDs several distinct advantages when it comes to operations. For example, LEDs have an advantage when used in conjunction with occupancy sensors or daylight sensors that rely on on-off operation. Also, in contrast to traditional technologies, LEDs turn on at full brightness almost instantly, with no delay. LEDs are also largely unaffected by vibration because they do not have filaments or glass enclosures.
Old Apr 5, 2019 | 11:16 AM
spindos's Avatar
spindos
Good to know. Thanks guys.
DiabloX22
GX - 1st Gen (2003-2009)
Jan 21, 2018 05:49 PM
gsfdream
GS F (2016-present)
Sep 11, 2017 09:46 AM
rselby
Lighting
May 19, 2016 09:42 AM
jmack2688
Mar 12, 2015 11:45 PM
nirav325
May 18, 2008 01:26 PM
