255/45 Rears and 225/45 Fronts??
Old Mar 1, 2019 | 10:55 PM
SikhSipahi's Avatar
SikhSipahi
Default 255/45 Rears and 225/45 Fronts??
Anyone running 255/45 Rears and 225/45 Fronts setup on stock wheels and suspension?? Any rubb?? So sick of potholes bending the rims.
Also anyone knows a good place to buy OEM Wheels at reasonable price??
Old Mar 2, 2019 | 07:01 PM
arentz07's Avatar
arentz07
The diameters would be different between those two tire sizes. If you want to go up, you could do something like 225/45 and 255/40. @ShrinkDoc runs a setup with increased sizes like that, if I recall correctly.
Old Mar 2, 2019 | 07:31 PM
KYLexusMkr's Avatar
KYLexusMkr
I agree, two different diameters with that setup, which isn’t too big of deal on rwd, but an awd will lead to trans issues. As for inexpensive oem wheels, the best bet is to have them repaired if they’re salvageable. Other than that, best to look at all the online market places. Good luck, hope things get better.
Old Mar 2, 2019 | 08:53 PM
SikhSipahi's Avatar
SikhSipahi
It's RWD. Would love to hear from shrinkdoc about his setup. The bends aren't too bad, I have to go the repair route. Called 3 stealerships, complete rip off. Also couldn't find a single set online anywhere except ebay selling refurbished sets.
EDIT: Went digging through shrinkdoc's posts. He runs 255/45/18's in the rear, and 225/50/18's on Front. Keeping in mind, his AWD suspension is slightly higher than RWD suspension. I should be fine running 255/45/18 Rears and 225/45/18 Fronts or 255/40 R and 225/45 F as I have a RWD.
Old Mar 2, 2019 | 11:17 PM
arentz07's Avatar
arentz07
Thumbs up
Ah, gotcha. I don't know how, but for some reason I thought you were AWD. It's probably safest to run the same diameter, but teeeeeeechnically you should be good with either of those you mentioned above.
Old Mar 3, 2019 | 07:19 AM
TonyN's Avatar
TonyN
If you want to keep relative front and rear heights the same while increasing overall diameter then I would suggest
225/45/18 and 255/40/18
You can also move the front to 235/40 and rear to 265/35
another thing you need to consider is that every manufacturer is not equally. Nitto are narrow when compared to pirelli, when I went shopping for rear tires for 305 series tires there nitto were about 1/2 narrower then the pirelli Pzero, both were 305/25/19, i ultimately went with 335/30/19 Nitto Nt05 for my Supra.
Old Dec 9, 2020 | 10:34 AM
MAXXXICE's Avatar
MAXXXICE
The setup that TonyN mentions sounds great and is within the 1% rule for AWD similar circumference; at .4%. My questions would be if the 265's would fit on the stock 18x8.5 safely and if the 235's would rub on fronts. Thoughts???
Old Dec 9, 2020 | 11:18 AM
Sasnuke's Avatar
Sasnuke
As a reference, I run 18x8.5 235/40/18 front and 18x9.5 265/35/18 rear, lowered on RSR Downs.
Both front and rear clear without rubbing, but that's also due to the offset of the rims.
For OEM rims a 265 is too wide for the factory 18x8.5 rim.
Old Dec 9, 2020 | 01:34 PM
laobo979's Avatar
laobo979
Originally Posted by Sasnuke
The tire size of 265/35/18 doesn't exist as far as I've researched.
They do exist as few manufacture make them. Even on this forum there members running that size on the stock 18x8.5 without issues. Plus the fact your running that size yourself make nosense on what you just said.
https://www.clublexus.com/forums/is-...5-35-18-a.html
Old Dec 9, 2020 | 02:20 PM
Sasnuke's Avatar
Sasnuke
265/35/18 is a real tire size, but it's still too wide for an 8.5 rim. Manufacturer recommended fitment is still 9 inches minimum, and up to 10.5 inches maximum.
Old Dec 9, 2020 | 05:44 PM
laobo979's Avatar
laobo979
@laobo979 I suggest you actually read the thread you linked to confirm if any member actually installed a 265/35/18. Everyone talked about a 265/35/18, yet you don't actually see one in the thread.
And if you have a link to even one 265/35/18 on planet earth, please provide it...in addition, appropriate sizing for a 265/40/18 tire starts at 9 inches rim width. If a 265/35/18 did exist, the minimum rim width would be the same.
I suggest you read the first reply to that link.
Old Dec 9, 2020 | 05:53 PM
Sasnuke's Avatar
Sasnuke
Ok...that way my mix up. The tire that doesn't exist is the 265/30/18...that's the size I wanted to match my 235/40/18 on the front, it is the one that doesn't exist.
I have 235/40/18 and 265/35/18 on my car now. My bad...
However, the 265 is still too wide for an 8.5 inch rim, according to manufacturers specs.
But then again people 225 on a 10.5 rim, so really where is the safety at that point.
Melomelo
Feb 20, 2018 08:09 PM
hakmeister
Oct 24, 2014 08:34 PM
Dj_AmtraX
Nov 8, 2006 10:27 AM
Neil64
Wheels, Tires & Brakes Forum
Jul 11, 2006 09:14 AM
Aclarke
May 26, 2006 10:35 AM
