Max tire size
Old Nov 6, 2006 | 11:04 PM
Dj_AmtraX's Avatar
Dj_AmtraX
Default Max tire size
I am looking at some 19"x8 O.Z. rims. What is the biggest I can go on the tires? 245/35/19 or bigger?
Old Nov 6, 2006 | 11:19 PM
jsquared's Avatar
jsquared
so i guess that means a non-staggered setup? do you have an AWD 250? you probably won't wanna go more than 245/35 on the front for 19". i think very few people have had minor rubbing with 245s on the front. have you lowered your car yet?
Old Nov 7, 2006 | 11:50 PM
Dj_AmtraX's Avatar
Dj_AmtraX
RWD with Stock suspension. No plans to lower. What is purpose of staggered set-up? Can I go bigger than 245/35/19?
Old Nov 8, 2006 | 12:07 AM
jsquared's Avatar
jsquared
well i think if you have rwd, its staggered. from the aftermarket wheel thread,
17" RWD:
Front: 225/45/17, 17x8 +45mm
Rear: 245/45/17, 17x8, +45mm
18" RWD :
Front: 225/40/18, 18x8, +45mm
Rear: 255/40/18, 18x8.5, +50mm
try there to see what people are using...
personally, with a lowered setup i'd go 235 max up front and 275 max on the rears. since yours isn't/won't be lowered, you can probably go 245 up front. i'd still not go more than 275 in the rear. i think this will work so you won't have to roll the fenders or anything.
Old Nov 8, 2006 | 01:03 AM
ES3's Avatar
ES3
17" RWD:
18" RWD :
Any idea if the stock IS300 17inch rim could fit on an IS350? I need a winter set of rims/tires!
Old Nov 8, 2006 | 01:15 AM
jsquared's Avatar
jsquared
i think they do. they should have the same bolt pattern, so they should fit. joez had/has the new GS300 wheels on his IS300. if you're wondering where i'm going with this, its that most lexus wheels in similar categories (GS/IS) should have the same bolt patterns and if the rim has the right bolt pattern for the car, it will fit.
just double-check that the IS300 rims are a 114.3 bolt pattern and you'll be set!
Old Nov 8, 2006 | 09:33 AM
ES3's Avatar
ES3
Thx a bunch, now for the "mandatory stagger" do you think it's really critical? I've been told that the IS350's computer MUST see a wider total diameter in the rear for the ABS etc to work? Of course the IS300 rims are the same size all around. Think I might be able to make this work?
Old Nov 8, 2006 | 09:34 AM
ES3's Avatar
ES3
DJ, regarding your question, I would definitely go here to see what they suggest fits:
www.tirerack.com
Old Nov 8, 2006 | 09:45 AM
javyLSU's Avatar
javyLSU
2IS OG
I'd be careful with that - although the bolt pattern is 5x144.3, remember you have some pretty beefy brakes to clear in the front
Javier
Old Nov 8, 2006 | 10:27 AM
ES3's Avatar
ES3
Javier
Yeah, it's probably not a reality. Is there anyway to measure clearance on that, with someone who has the rim? Or is putting it on my car really my only option?
I may just start a thread on this. Cuz it's killing me not to know.
nagooyin
Oct 7, 2021 09:13 AM
acnup00tl
May 13, 2019 06:14 PM
monoglot
Sep 22, 2018 12:27 AM
seng278
Apr 3, 2018 12:11 AM
dynamax
May 20, 2009 09:12 AM
