Keyless Entry Sensors
Old Nov 7, 2018 | 07:43 PM
Pittsy's Avatar
Pittsy
No, it doesn’t. keyless start works tho. hmmm
Old Nov 8, 2018 | 06:49 AM
Pittsy's Avatar
Pittsy
Talked with the wrap guy, going to go in and he's going to pull the panels off and double check everything. Better than paying lexus for the labor to do it. If the wrap shop cant fix it then i'll just go to lexus to get the issue resolved when i get the new card key. The wrap guy owns a 3IS and says his lock and unlock sensors work perfectly fine with vinyl over them. while i'm there i'm going to get some issues worked out of the wrap too.
Old Nov 8, 2018 | 07:32 AM
loophole35's Avatar
loophole35
Sounds like the handle is not plugged in.
Old Nov 8, 2018 | 07:34 AM
Pittsy's Avatar
Pittsy
Im hoping thats the case, as easy as it sounds to fix, but the courtesy and interior lights dont turn on when i approach the vehicle.
Old Nov 8, 2018 | 07:39 AM
GTR20's Avatar
GTR20
So I wrapped my handles and the lock and unlock features still work. The lock feature sometimes is a little bit harder to trigger but I just squeeze the top and bottom sensors to lock it. Without the wrap it’s a lot more sensitive but mine still work.
Old Nov 8, 2018 | 07:49 AM
loophole35's Avatar
loophole35
Well the transmitter is part of the handle too IIRC so if it's unpluged it will not detect the key.
Old Nov 8, 2018 | 07:50 AM
Pittsy's Avatar
Pittsy
Ah thanks for clearing that up. Just relieved a bunch of stress, thanks!
Old Nov 8, 2018 | 09:12 AM
Ajowhan's Avatar
Ajowhan
there you go! I tried looking for information about the transmitter but google map is not as helpful with something like this..
That makes a lot more sense, I was gonna suggest rebooting the ECU if its the programming issue but that should be it
Old Nov 8, 2018 | 07:57 PM
Pittsy's Avatar
Pittsy
Just got back from the shop who wrapped the car. They popped the door panels off and found the sensor on both door handles to be unplugged! All problems solved! Thanks for all the help everyone!
MickeyS
GX - 2nd Gen (2010-2023)
76
Nov 9, 2023 12:41 PM
daryll40
RX - 4th Gen (2016-2022)
58
Jul 2, 2022 08:41 AM
jkonquer
Nov 2, 2015 02:44 PM
HSLexster
HS 250h Model (2010-2012)
Feb 7, 2015 02:13 PM
Seeker4
RX - 3rd Gen (2010-2015)
22
Mar 22, 2014 07:34 PM
