DIY oil change surprise
When I removed the old filter, there was no smaller ring to be found! I fumed a bit, and installed the new filter using both large and small rings.
When I called Lexus to complain, I was told that they don't use the small ring! They said it serves no purpose but to facilitate a "clean drain", which I do not understand.
I was absolutely dumbfounded that they would give you a rubber ring and not expect it to be used!
Step 1) The oil filter housing assembly includes an outer "Access window" if you will that loosens with a 3/8" drive ratchet extension. The oil doesn't drain when you remove that "access window" cap until you stick the included plastic drain spout with it. Then you perform a "Clean drain." as the oil is a clean directed stream. You then replace THAT smaller o-ring when you remove that "cap."
The filter remains on the car.
Step 2) Then after it drains, THEN you remove the actual filter housing using the large Toyota oil filter socket tool. Then some more oil drips out.
You can perform step 2 without performing step 1 and achieve the same result. Step 1 is for convenience and cleanliness though so you don't get a bunch of hot oil all over your hands and all over the ground. But it is doable. If you do JUST step 2, you can skip the install of the new small o-ring.
I'm coming from an '04 IS, so I'm used to oily messes when removing the oil filter
Broke my 1/4 drive wrench trying to take off the oil filter canister. 1/4 is what I keep in the trunk and thought my plier style oil filter wrench would be sufficient anyways. That cannister lid for the filter is on there TIGHT. 1st time I've done this car so the shop did this.
So I already dropped all the oil and replaced without filter. I will go grab my 3/8" drive and redo in a couple days so I get the new filter in there.
Opinions...should I drain all the oil again starting from drain plug? Should I just remove filter and catch whatever comes out there and top off with new oil? How much could I expect to get out? Or if I don't insert the little drain plug will nothing come out? 1st oil change I've done on a car with this style oil filter.
Took only 6 qt to fill without having removed the filter.
If it were me, I change every 5k, I'd just take the filter out, and top it off.
I'm no professional but I don't think it'd be a big deal if you did it every 10k
Lexus recommends oil changes every 10k,
unless you drive under "special operating conditions" , where they recommend every 5k
defined on p.44 on the Warranty/Service manual:
https://www.lexus.com/pdf/service/MY...350_WSG_lr.pdf
Your 1/4 drive ratchet didn't stand a chance...
As already mentioned, I never bother with the filter drain/small o-ring. I just open the entire filter housing partially and let it drain out slowly so it doesn't make a mess.
Does 1 qt sound excessive to expect to come from filter housing? Guess it doesn't matter it's at a good level now and I'll find out tomorrow.
Just concerned about it making a mess in there on the engine floor board.
Ha...yeah anytime you put an extension on a 1/4" drive you get a "this is dumb" feeling. It's just what I keep on me hadn't appropriately prepared for the canister style filter housing.
