Work Kiwami Setup??
Old Aug 2, 2018 | 09:55 PM
jameshan's Avatar
jameshan
Default Work Kiwami Setup??
Looking to get some wheels finally. Currently dropped on bc racing coilovers. Can anyone with Work Kiwami's on 19's recommend a safe staggered set up that is rub free with decent offset? Gotta daily the car so not looking for super aggressive set ups that take a lot of work or hassle to get right. I know theres a lot of specs on the wheel forums but there is 10000000000000 of them to look through and it just makes it that much more confusing. Just hoping someone has found the general flush to fender without rubbing specs.
Thanks
Old Aug 3, 2018 | 07:29 PM
faisal11ir's Avatar
faisal11ir
Hey consider this setup
-Fronts 19x8.5 +35 with tires 235/30/19.
-Rear 19x9.5 +38 with tires 265/30/19.
Old Aug 4, 2018 | 12:56 AM
jameshan's Avatar
jameshan
How'd that set up work out?
Old Aug 4, 2018 | 08:13 AM
faisal11ir's Avatar
faisal11ir
working well
Old Aug 4, 2018 | 09:19 AM
Sasnuke's Avatar
Sasnuke
That’s pretty much your standard setup to guarantee no issues.
Of course depending on how low you are will really depend on final figment.
Worst case a slight adjustment to the coil overs would probably solve any minor issues.
Old Aug 6, 2018 | 09:59 PM
jameshan's Avatar
jameshan
Okay cool. Thanks guys. I will try it out and let you know!
Old Aug 23, 2018 | 06:59 PM
bliao's Avatar
bliao
Hi there,
I'm running the following setup without any rubs.
Front: ET35 8.5J tire:235 35 19 NEXEN
Rear: ET38 9.5J tire: 255 35 19 NEXEN
I've tested the rub issues with 2 adults rear seat and fully loaded trunk. Rub FREE!
Old Aug 23, 2018 | 10:22 PM
jameshan's Avatar
jameshan
Originally Posted by bliao
Hi there,
Sweet. It looks great! Looking forward to running those wheels.
Old Aug 24, 2018 | 11:02 AM
Meraki Autoworks's Avatar
Meraki Autoworks
Your #1 Lexus Vendor
Contact us for pricing on Work wheels!
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Old Aug 24, 2018 | 11:08 AM
Answer's Avatar
Answer
That setup:
Won't work if the car is AWD though.
Old Aug 25, 2018 | 12:09 AM
jameshan's Avatar
jameshan
Originally Posted by Answer
That setup:
Oo. Forgot to mention I am AWD. Does the specs from the earlier post work with awd? I think it's just tire specs that are diff. 35 to a 30.
Old Aug 25, 2018 | 06:24 AM
Answer's Avatar
Answer
You have to make sure the external diameter stays the same.
Stock setup has a 0,24% difference front to back. Don't know what the max tolerance is, but stay close to that.
you would need to go 225/35-19 and 265/30-19, which is a 0,23% difference.
Old Aug 26, 2018 | 05:52 PM
bliao's Avatar
bliao
Forgot to mention that I'm RWD.
Old Aug 27, 2018 | 06:44 AM
faisal11ir's Avatar
faisal11ir
Be careful as 35 at the rear is actually giving you more speed, i had that rear setup and was going 7 km above speedometer and received a lot of radar tickets that's why i suggested 30 at the rear.
Looking good by the way!
Old Aug 27, 2018 | 12:46 PM
jameshan's Avatar
jameshan
So to clarify I should go with this as AWD?
-Fronts 19x8.5 +35 with tires 225/35/19.
nano10
Jul 23, 2014 10:18 PM
tmoore8878
Mar 13, 2012 12:37 PM
masboy
Sep 28, 2007 12:42 PM
klthomas
Wheels, Tires & Brakes Forum
Oct 3, 2006 01:19 PM
