when I start my car the tire pressure is as low as 29 and as I drive it might go to 33----I live in hot florida----is this normal?
Yes, that is normal, as the tires get hot the psi will slightly increase. 29 is pretty low, might want to add some air to those tires.
Napalvr
close
- Join DateJan 2015
- LocationMichigan
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:85 Times in 66 Posts
Quote:
Here in Michigan I set mine to 35 cold and maybe the pressures go to 38 or so. I’ve had no abnormal tire wear at these settings Originally Posted by siestakey
Your driver side door has a sticker stating the recommended tire pressure.. 29 is low.
It should be 36 cold, and will eventually warm up to ~39 driving.
Sasnuke
close
- Join DateFeb 2017
- LocationRichmond Hill, Ontario, Canada
Liked:1,752 Times in 1,377 Posts
Quote:
Originally Posted by Flash5
Mine are at like 36/37 then 39ish once I’ve been driving a while.
Make that 3 people for the same comments above.Originally Posted by nathantse
Your driver side door has a sticker stating the recommended tire pressure.. 29 is low.It should be 36 cold, and will eventually warm up to ~39 driving.
that's why more people are switching to nitrogen, specially if you see dramatic temperature changes between day and night
arentz07
close
- Join DateNov 2016
- LocationGA
Liked:4,788 Times in 2,371 Posts
Quote:
I ran nitrogen when I first got the car for a while, and have been using air recently. I haven't noticed a big difference between the two. What makes the most difference is direct sunlight versus shade, IMO.Originally Posted by otakusan
E46CT
close
- Join DateMar 2016
Liked:2,585 Times in 1,913 Posts
you need to fill the tires every 3 months or so. They'll tend to lose pressure even with a new wheel and new bead. leaking beads, hardened rubber, valve stem seals etc only make the problem worse.
so at 29 you definitely have not filled air for a good while now. Get it back up to 35-37 when cold. Rinse and repeat after a few months.
2013FSport
close
- Join DateAug 2017
- LocationOR
iTrader Positive Feedback100
iTrader Feedback Score(2)
Liked:1,572 Times in 1,303 Posts
Do keep in mind that the door sill pressure recommendations are for a fully loaded vehicle...
That said, running the max pressure listed here will likely wear the center out of your REAR tires over the course of 20,000mi if you run around solo and don't have 25 gold bars in the trunk.
As for the front; if your edges are being eatin alive, you might opt to run the max pressure up front.
Flash5
close
- Join DateApr 2018
- LocationGA
Liked:459 Times in 367 Posts
Last I checked, the sticker on the door has the recommended values not the max. Originally Posted by 2013FSport
Do keep in mind that the door sill pressure recommendations are for a fully loaded vehicle...That said, running the max pressure listed here will likely wear the center out of your REAR tires over the course of 20,000mi if you run around solo and don't have 25 gold bars in the trunk.
2013FSport
close
- Join DateAug 2017
- LocationOR
Wording on the 2IS reads xx.x psi w/5 passengers 825lbs.Originally Posted by Flash5
Implying max load and cold pressure setting.
Like yours, it does not offer a minimum load/psi. Likely confusing for some?
Obviously the tires choosen should exceed the cars maximum load per tire. That said, many read the tires Max PSI which is the wrong information. Well unless the tires max load matches the cars max load. Then the pressure may be correct.
Flash5
close
- Join DateApr 2018
- LocationGA
You’re talking a 2IS I’m talking a 3IS which are 2 different generations of cars. This is a 3IS thread. Originally Posted by 2013FSport
Wording on the 2IS reads xx.x psi w/5 passengers 825lbs.Implying max load and cold pressure setting.
arentz07
close
- Join DateNov 2016
- LocationGA
Let's not revive this thread: https://www.clublexus.com/forums/is-...ire-psi-3.html
Seriously, as long as you have stock wheels, just following the sticker on the inside of the door, except for rare cases such as track days.
Flash5
close
- Join DateApr 2018
- LocationGA
Lol yeah true. Originally Posted by arentz07
