Trunk spring
Old Jul 1, 2018 | 11:28 PM
trinhtd's Avatar
trinhtd
Default Trunk spring
So recently I replaced my trunk with a carbon fiber seibon trunk. Due to the light weight of the trunk, the springs are too strong and make the trunk fly open when i press the trunk release button. Is there any way to remove the spring or reduce the tension?
Old Jul 2, 2018 | 01:35 PM
tofuprod's Avatar
tofuprod
I found this on the GS forums, not sure if this applies to the IS platform though, but it's worth a look.
https://www.google.com/search?q=trun...hrome&ie=UTF-8
Old Jul 2, 2018 | 10:37 PM
jameshan's Avatar
jameshan
I just got in the habit of having my other hand on top of the trunk to catch it when I open mine.
Old Dec 2, 2018 | 01:20 AM
UngBuck's Avatar
UngBuck
https://www.clublexus.com/forums/gs-...e-big-pic.html
His trunk is heavier. so he adjusted the tension to stronger. We got seibon trunk, which is lighter. so we need even less tension. NOT stronger tension. I don't think that would help. The only way I could think of is fabricating a shock hinge and install a trunk shock. It is annoying too. I almost got hit in the face by the trunk so many times.
Old Dec 2, 2018 | 02:32 PM
lychee416's Avatar
lychee416
So, did anyone check to see if GS trunk guide works for IS platform?
Old Dec 2, 2018 | 07:59 PM
trinhtd's Avatar
trinhtd
yeah my trunk is much lighter if it has the same adjustable holes like the gs i would probably just cut a new hole further away to reduce the tension on the spring
Old Dec 2, 2018 | 09:05 PM
itsx's Avatar
itsx
would it be possible to replace the little gas struts in there? for stronger or weaker lift?
peasodos
Feb 15, 2017 08:16 AM
czr73
Sep 25, 2015 06:27 PM
toRT LS430
Jun 17, 2014 10:37 AM
shiny250
Mar 12, 2010 08:13 AM
rbeermann
Dec 6, 2005 07:36 PM
