Stereo problem
Old Apr 17, 2018 | 08:06 AM
Jojose's Avatar
Jojose
Default Stereo problem
I have a 2014 is250 F-Sport and I recently changed the battery on it and now my stereo has no volume, I’ve checked all the fuse and they’re all working properly, I was wonder if anyone else has had this problem before and if so what do you recommend me doing to get to work again?
Old Apr 17, 2018 | 10:49 AM
Sasnuke's Avatar
Sasnuke
Does the volume number change when you turn the ****? If it doesn't, then it sounds like an Amp issue. Check the fuses under the drivers dash if you haven't done so already.
Old Apr 18, 2018 | 08:11 AM
xcorpion47's Avatar
xcorpion47
Check fuses its probably that you blew the fuse for the amp. I disconnected the amp this past weekend because I was hooking up a sub system and I forgot to connect the amp back and I didnt not have any volume.
Old Apr 21, 2018 | 04:17 PM
Jojose's Avatar
Jojose
I was able to fix it, just opened up the amp, cleaned it a little, pushed the button that says push and connected it back. Turned the car to find the audio working.
Old Apr 21, 2018 | 07:43 PM
Sasnuke's Avatar
Sasnuke
Could you see what was on the other side of the circuit board from the PUSH stamp?
Old Apr 21, 2018 | 07:46 PM
Jojose's Avatar
Jojose
It seemed like 3 black circles and you can hear the click once I would press it
Old Apr 21, 2018 | 07:49 PM
Sasnuke's Avatar
Sasnuke
Maybe some type of circuit breaker...interesting. Good to know that is there.
Old Apr 21, 2018 | 07:51 PM
Jojose's Avatar
Jojose
Did you run into the same problem as well?
Old Apr 21, 2018 | 08:02 PM
Sasnuke's Avatar
Sasnuke
No...but it seems a few others have after battery replacement. No one has mentioned that PUSH part yet...until now.
ambrown307
Nov 4, 2024 03:57 PM
nycuban87
RC - 1st Gen (2015-present)
Dec 23, 2018 07:59 PM
Jojose
Apr 17, 2018 06:02 AM
Toddski
Mar 26, 2018 11:07 AM
Tim
Oct 22, 2004 04:19 AM
