2014 is250 F Sport stereo problem
I have a 2014 is250 F-Sport and I recently changed the battery on it and now my stereo has no volume, I’ve checked all the fuse and they’re all working properly, I was wonder if anyone else has had this problem before and if so what do you recommend me doing to get to work again?
Wrong forum bro...this is the v8 ISF forum.
Amazes me as to how many F-sport guys post on this forum.....is it not clear that this is the ISF forum???
But to answer your question, the problem clearly is the factory amp not being on/not working. SOMETIMES, when you reconnect power/reconnect the battery, or jump a vehicle off, the factory amp (some vehicles the radio fuse would blow), would blow the fuse. Better hope that's the case for you as a fuse is a few cent and the factory amp, although not worth 5 cent, will cost you close to a grand with install from the dealership.
Good luck and remember, post in the correct forum next time! Do a search there also as some of your F-sport buddies may have had the same issue and may have posted their findings👍
V.
V.
TwentyTen
Nov 11, 2006 03:06 PM
illimental
Dec 30, 2005 12:11 AM
