14' IS350 Display Screen Front Glass Replacement
I recently purchased a 2014 is350 f sport and the display screen is cracked, along with that little strip in front of it, that I assume is used to replace the screen itself. The screen works great, just the glass is cracked. I read somewhere that the dealership sells them, where could I find the part#? or is there another reasonable place to get one. Also, if there is a replacement guide out there please let me know.
Thank you!
SJ
Thank you!
SJ
Got a picture of the crack?
There is a TSB for the front display for anti glare coating coming off. Wouldn't hurt to try to see if Lexus service dealership to see if they can replace it under warranty.
try wetting a micro fiber and rubbing it to see if you can mess up the coating on it and bring it in and see if Lexus dealer will take care of it under TSB (L-SB-0002-16).
https://www.clublexus.com/forums/is-...s-damaged.html
My dealer has this part on order under the TSB for me. The part number on the invoice 86134-53030. If dealer denies your claim because of the cracked glass, the part is pretty cheap and takes only a few minutes to pop in and out I read somewhere.
https://www.lexuspartsnow.com/parts/...134-53030.html
trdsw20
Jul 13, 2008 12:53 AM
