Window Trim/Chrome delete
Old May 5, 2017 | 05:12 PM
Antnie2418's Avatar
Antnie2418
Thanks for your option ! However if you knew anything about these films you would know that the light transparency is very good even with a dark tint never mind the light tint which is installed. Believe it or not so your opinion on not being safe or illegal is wrong.
Originally Posted by E46CT
i wouldn't overlay over the DRLs. that gives you the signature look to a Lexus. Plus its probably not safe, not to mention illegal. not to mention doesn't look good. Leave it high end professional pure stock!
Old May 7, 2017 | 05:51 PM
jmull3r's Avatar
jmull3r
i want to wrap only the window trim in gloss black on my 2017, doors anyone think that will look weird with the chrome front end because i wanted to leave that alone, i like the gunmetal chrome look around the grille
Old May 7, 2017 | 06:25 PM
robert2423's Avatar
robert2423
go with the satin black gloss is meh... you will see it definitely see more dirt with the gloss its annoying and maintenance of the wrap. OR F it do RED
Old May 10, 2017 | 12:09 PM
ryanwongg's Avatar
ryanwongg
Originally Posted by Antnie2418
I used gunsmoke basically just take your time and cut it out. I neetted the bottom of the Trina fb cut it to the top
Thanks Antnie! sorry for the late response, I am just now seeing that you replied! Regarding the window trim, are you saying you precut the strips of film and then laid it on top?
Do you have any close ups of how the chrome now looks with gunsmoke is laid on top?
Old May 11, 2017 | 06:41 AM
Antnie2418's Avatar
Antnie2418
Sure Ill take a couple close up pictures ... I bought 12" film and cut the strips that I needed. There are seems nothing you can really do unless you order very wide film and you would have alot of waste
Old May 11, 2017 | 11:19 AM
itsx's Avatar
itsx
How much vinyl did you guys use for the trims? is 5'x4' enough for the windows and grille?
Old May 13, 2017 | 03:30 PM
srv777's Avatar
srv777
Would 4"x60' size like this work?
http://www.lamin-x.com/4-x-60-Roll-o...lm-p/460-t.htm
Old May 16, 2017 | 10:42 PM
ryanwongg's Avatar
ryanwongg
Hey Antnie, reminder for the close up pics
Old May 25, 2017 | 09:03 PM
howudoinn's Avatar
howudoinn
I'm also wondering if the Lamin-x size 4"X60' be enough for the window trims and front grill trim. Any information would be appreciated. Thank you.
Old May 26, 2017 | 08:15 AM
ryanwongg's Avatar
ryanwongg
the 4"X60' will be enough as you can split the 4" width into 2" pieces and then have plenty to spare for the grill trim. However, i'd advise against the gunsmoke color as the chrome can give off a purple hue in direct sun. Unless you're into that... Perhaps the next shade darker would be better -smoke.
MRonan83
GS F (2016-present)
15
Sep 16, 2020 11:01 AM
FUZCO
RC - 1st Gen (2015-present)
Aug 29, 2015 06:09 PM
Wald GS
GS - 1st Gen (1993-1997)
May 18, 2006 12:23 AM
