ABS And Side Assist fault after lowering spring install.
Old 03-08-17, 06:28 PM
DoWerk
DoWerk's Avatar
Default ABS And Side Assist fault after lowering spring install.
Hey guys, I had the RSR superdowns installed last week, after a day of driving my ABS and traction light came on, also my side assist system fault light is on and it is not functioning. Has anyone experienced this, is there an easy fix? I've tried disconnecting the battery to see if it would clear the system faults but it didn't solve anything.
Thanks in advance for your help.
Old 03-09-17, 05:26 AM
vodee3is
vodee3is's Avatar
make sure the ABS sensors are all connected, i just put RSR superdowns on my is a few days ago and no problems. thats the only thing i could think of
Old 03-09-17, 02:16 PM
DoWerk
DoWerk's Avatar
no other information on this?
Old 03-09-17, 04:09 PM
dnasians
dnasians's Avatar
It sounds like you either forgot to connect one of the ABS units back, or you pinched/cut a wire.... i would go back down there and check that everything is connected/operating properly
Old 03-09-17, 07:50 PM
Solara350
Solara350's Avatar
u broke one of the 4 ABS sensors my friend, normal ODB2 can't read you need specially high tech scanner to see which one is faulty. once u know which is bad one just replace with and thats it no need to reset or anything, drive for 100m the system will reset itself.
Old 03-10-17, 07:56 AM
DoWerk
DoWerk's Avatar
hmm okay, and this has an effect on the side assist (blind spot monitor) as well?
Thanks
Old 03-10-17, 01:14 PM
Solara350
Solara350's Avatar
Thanks
When ABS sensors malfunction it will disable Traction system, i'm not sure about BSM because it has nothing to do with the suspension "Unless they shared the same sensor" and i'm sure one of your ABS sensor is dead, In car technologies usually 1 sensor down it will make other related one down with them to for safety reason, that's why they have scanner and diagnostic to see which one is the problem one. We here to assume and give you some info, nobody 100% sure bro, good luck.
Old 03-10-17, 05:01 PM
Sasnuke
Sasnuke's Avatar
Received 1,732 Likes on 1,368 Posts
Thanks
This is likely why the BSM light is on...it has a code that relates to the Vehicle Stability control systemDTC NO.
C1A45
DETECTION ITEM Vehicle Speed Sensor
DTC DETECTION CONDITION A fail flag is transmitted from the skid control ECU
TROUBLE AREA
  • Vehicle stability control system
  • Blind spot monitor sensor LH
  • Blind spot monitor sensor RH
Fix the sensor issue at the wheel, and the BSM light should go out.
Old 03-10-17, 05:07 PM
Solara350
Solara350's Avatar
C1A45
TROUBLE AREA
that's what i thought, they do share sensor.
Old 03-10-17, 05:17 PM
Sasnuke
Sasnuke's Avatar
Indirectly yes...the BSM system needs to know the vehicle is moving, but because there is a problem with the vehicle speed circuit (likely a disconnected sensor) and it triggered an ABS code, that automatically triggered the BSM code.
If the lights did not come on immediately after the vehicle was lowered, and I mean literally when the vehicle was first started, there is a good chance a sensor wasn't plugged in properly and the connector just come off the sensor after the vehicle was driven for awhile. Hopefully plugging it back in will cure everything.
Old 03-10-17, 06:55 PM
DoWerk
DoWerk's Avatar
You guys nailed it, the abs sensor harness was short slacked and popped out on a sharp turn. reconnected the sensor and all is good. Thanks for the help guys!
Old 03-10-17, 06:57 PM
Sasnuke
Sasnuke's Avatar
CL Team effort!!
Old 03-10-17, 07:26 PM
Solara350
Solara350's Avatar
Thats what we here for, sharing and helping .
Old 03-10-17, 07:28 PM
Solara350
Solara350's Avatar
Thanks for your great info bro, lol i need to update myself hahaha i thought BSM shared the mirror Light sensor but i was right 80% haha
aymaddemir
02-25-17 11:24 AM
mrnorwall
10-26-09 11:08 AM
faithless
06-20-08 01:36 AM
doyo
03-21-08 09:37 PM
thwang99
Suspension and Brakes
08-12-02 08:41 PM
Quick Reply: ABS And Side Assist fault after lowering spring install.
