Uneven ride height after alignment help
Old Apr 7, 2019 | 04:58 AM
  #31
Shaftplay's Avatar
Shaftplay
Originally Posted by HOMER350
There may be something going on here but before we jump to conclusions maybe read my resolve on previous post.
The rear wheels can be on a flat surface, but if the fronts are not equally level OR at an equal height as the rear this can cause an alarming amout of difference in height.
So checking this on a any kind of slope, in my experience, can also cause same issue.
I parked the car several ways, multiple places...and when I got to the shop and parked on a 100% flat concrete surface was the only place it measured equal on both sides.
Same concrete surface they founded their lift into so as flat as concrete gets. I though they were screwing with me and secretly had it slightly lifted slightly cause it was in between the lift
Tried every position on a flat surface. No dice.
Got an alignment, that did jack squat.
Not sure what the issue is. I'll jack up the rear end today and remove both rear wheels
Old Apr 7, 2019 | 05:08 AM
  #32
Answer's Avatar
Answer
Is it just me or the correct height seems to be driver side? Check to make sure the spring is correctly seated on the lower arm, they're easy to misalign, and would cause the ride to be higher.
Old Oct 31, 2021 | 05:46 AM
  #33
Soldat79's Avatar
Soldat79
I have exactly the same issu, 1 inch more at the rear passage side. In this thread Sansnuke said
Originally Posted by Sasnuke
....I think the easiest and most obvious thing is to check the orientation of the passenger side spring in the perches. It's probably not sitting in the right spot.
How it's possible that the spring is not in the good orientation ? This morning I take off my wheels and I check the springs they are in their place everything looks good!
Old Oct 31, 2021 | 05:57 AM
  #34
Sasnuke's Avatar
Sasnuke
Is your vehicle lowered or do you have the stock suspension?
If the vehicle has the stock suspension then confirm the surface you're measuring the vehicle height on is flat. Ideally you want a surface that you can guarantee is flat, either metal (like an alignment hoist) or possibly concrete (like a garage floor).
Surfaces like asphalt or gravel won't be even and therefore the measurements will not be accurate.
Old Oct 31, 2021 | 06:37 AM
  #35
Soldat79's Avatar
Soldat79
Hey, yes it s OEM spring/suspension. I made the measure in a garage, perfectly flat, I made measure in both direction. In all case the rear passager is more hight.
Ps: the front passenger is around 1/4inch more than the front driver.
Old Oct 31, 2021 | 12:01 PM
  #36
Sasnuke's Avatar
Sasnuke
Did you measure from the ground to the fender or from the center of the wheel to the fender?
Center of the wheel to the fender would be best.
Old Oct 31, 2021 | 07:47 PM
  #37
swaangin's Avatar
swaangin
I noticed (with naked eye) that on stock springs / RSR down springs, driver side was a bit lower on even pavement. I thought it might have to do something with the fact that we're sitting in our seat and putting pressure on the springs which is compressing it more
Old Nov 1, 2021 | 03:14 AM
  #38
Soldat79's Avatar
Soldat79
I measured from the ground to the fender, but everybody see the difference on my car without a measure tape.
Old Nov 6, 2021 | 12:33 AM
  #39
Soldat79's Avatar
Soldat79
No idea to solve this issu ?!!
Old Nov 6, 2021 | 05:54 AM
  #40
wthrman2's Avatar
wthrman2
I think that there was a few attempts to help out but didnt seem to work. Have you taken it to the dealer? Sometime, taking it to the dealer is unavoidable...
Old Nov 6, 2021 | 07:14 AM
  #41
Soldat79's Avatar
Soldat79
Ok, I got to go to the dealer for the 125 000km overhaul, I will to explain them. I'll tell you after that.
Letsstance
Suspension and Brakes
Mar 28, 2015 12:37 AM
mikomill
Aug 24, 2012 12:45 PM
MDSC
Nov 18, 2011 03:26 PM
Sheehan1p
26
May 29, 2011 11:54 AM
beaterKU
Apr 21, 2005 10:14 PM
