Uneven ride height after alignment help
F sport lowering spring and rear camber kit were installed last month. Recently i took my car for alignment. The rear ride height was even, having -.8 camber on rear left and -1.7 on rear right. After alignment, the rear left was set to -1.7 and -1.6 on the rear right. Now the rear left sits .5 inch lower compared to rear right.
Does camber affect ride height? What do i need to do to maKe the height even? change the rear left camber back to .08 or i should i just install back the original camber arms. |
Originally Posted by gvan1998
(Post 9153107)
Does camber affect ride height? What do i need to do to maKe the height even? change the rear left camber back to .08 or i should i just install back the original camber arms. Did you measure the car immediately before, and immediately after the spring change? I recently lowered my wife's 3IS, including the camber arms, and had no issue. I did put it on the alignment rack immediately after the install and the camber came right in with minimal adjustment. I would be looking the spring install over very carefully. |
Check post #23 in this thread....
https://www.clublexus.com/forums/sus...ml#post9153455 I adjusted the new camber arms to mimic the length of the OEM arm, then bolted everything together. The camber adjustment at that point was over 2* negative as indicated in the post above. May be worth reading. |
Im thinking about just installing the factory camber arms back on. Its just too much problem. I went to the dealer 3 times already. First, they aligned the car without touching the camber. Second, They adjusted the left rear wheel with too much camber to -3.0.Third, they set the camber right but now the camber arm bolts are not installed correctly, on top of that they scratched my wheels. This is just frustrating.
just curious as to why you would install a camber kit in the first place when you're only on springs? tire wear is all base on the toe of the car unless you're planing on going with a wide and mildly aggressive wheels and coils or air later on.
everything aside I would double check everything because 1/2 an inch is a pretty big discrepancy. The camber adjustment should not have changed the height that much. |
Well I wanted maximum tire life, that's why I installed the camber kit. Without the camber kit, I will be at -2.2 or more, which will greatly reduce tire life. Yes I know that you need some negative camber for performance but Im not going to be autocrossing or racing. This is my daily commuter so I wanted look of a lowered car with maximum tire life.
Strangely enough, my driver side rear is about half an inch lower than the passenger rear (Left hand side steering wheel btw lol). This is on RSR Down springs.
I think this is normal behavior on this car. |
You had me wondering here... I just measured mine and driver side is actually about half an inch lower than the passenger side...
Completely stock 2015 350F... |
curious if this mystery has been resolved? I am running RSR Downs on my 2014 IS250 AWD + 15mm spacers all around. My driver side is lower than the passenger side. I haven't measure exactly but I thought maybe after installing camber kit it would properly align the wheels and ride height. I have no idea is that is true or not...
Originally Posted by jkwiseeyes
(Post 9592175)
You don't need camber kit on fsport lowering springs. The drop is so minimal (hardly noticeable) and I doubt you will be -2.0+ camber on the rear after install. Even then, -2 is still within specs! What you need to make sure is that you have 0 toe if you're worried about tire wear. I would remove those camber arms if I was you. Also, why is it that people think one need an alignment right after install? Let the spring settles then get an alignment. It's possible the springs have not settled properly yet and hence the difference in height you are getting.
Originally Posted by brendanf
(Post 9592207)
I think people might be forgetting what side of the car you sit on while driving. Your added weight without an equally weighted passenger is going to make the drivers side sit a little lower with time. I have never seen a set of lowering springs drop each corner of a car exactly the same. If you want equal wheel gap, then get air or coilovers so you can set the weight of each corner.
i will likely convert to coils as you suggested. thanks for your thoughts |
Originally Posted by 3ISRC
(Post 9592360)
Front -20mm to -25mm (-0.8inch to -1.0inch) Rear -10mm to -15mm (-0.4inch to -0.6inch) I'll have to find the results from my wheel alignment, I can't remember the exact #'s. So I waited almost a month before getting alignment because some friends told me they need to settle. However, when I went to get the alignment done the technician said there is no settling with springs. Too many conflicting opinions =/ I'm going to try to take it to the shop I had the springs install and see what they say. Thanks for your response! |
Old thread but speaks to exactly what I got going on.
Noticed today my car is about 1/2 inch lower on the driver side rear than the passenger side. RSR Downs, stock wheels, no chamber kit. Springs were installed just last month... had about 12k miles on them I think. Noticed it was maybe 1/4" lower right after install buy wasn't concerned. After all, there is more weight in the driver side of the vehicle. Can anyone confirm this is normal? Have the same thing after putting some miles on your RSR downs? OR, do I need to take it back to the guys who installed. |
Here are photos of the different heights. It looks more significant in person, about a 1/2" difference. Driver side being lower than passenger side.
https://cimg5.ibsrv.net/gimg/www.clu...369644a21a.jpg https://cimg4.ibsrv.net/gimg/www.clu...fd90ea63f1.jpg |
