Stereo input/Amp output wiring
Old Aug 12, 2015 | 08:43 AM
  #46
No0dLeZ's Avatar
No0dLeZ
Originally Posted by Loe
Hello all, thought I would share some information from the TIS. These are stereo to amp speaker inputs (not output) and shows ohm & watt values:
Was there additional info or picture to this post? Do you still have it? Can you re-post or PM?
Thank you.
Old Mar 14, 2016 | 12:14 AM
  #47
devinkato's Avatar
devinkato
I have a 2016 IS350 with non-ML stereo. Looking to do a 3-way active stage up front and dropping the rear fill, so I need to grab a full range stereo signal.
I'm understanding that I want to do this post-factory-amplifier - no problem.
Can anyone confirm:
1) Are the right and left front channel output of the stock amplifier full range?
2) Is the right and left front channel output of the stock amplifier flat?
3) Is there any volume-****-sensitive dynamic EQ'ing going on?
Thanks so much.
Old Mar 14, 2016 | 08:57 AM
  #48
No0dLeZ's Avatar
No0dLeZ
Can anyone confirm:
Thanks so much.
you can probably ask on this install
https://www.clublexus.com/forums/is-...ml-system.html
Old Mar 14, 2016 | 09:41 AM
  #49
devinkato's Avatar
devinkato
Thanks - I actually reached out to him on a car audio forum already. His last post indicated he was leaving the hobby, but I hope he still has time to answer my PM. I'll be sure and update this forum if I'm able to make any progress.
Old Apr 24, 2016 | 11:42 AM
  #50
Redshift's Avatar
Redshift
On the non ML audio system i used the white wire from the smaller wire harness connected to the factory amp.
Old Apr 29, 2016 | 10:01 PM
  #51
Sheazy's Avatar
Sheazy
Thanks for PDF files and wiring pins. Its 10x better than looking for color coded wires when theres 2 or 3 of the same color.
Old Jun 9, 2016 | 09:21 PM
  #52
waterchng's Avatar
waterchng
Reshift, what are you referring to here regarding the white wire. Is this for the remote signal?
Old Jun 9, 2016 | 09:40 PM
  #53
Redshift's Avatar
Redshift
Yes for the remote signal.
Old Jun 11, 2017 | 07:25 AM
  #54
r2digital's Avatar
r2digital
I found this thread quite informative as im getting ready to install my JL audio fix-86 + Xd 700/5v2. I decided to upload a a edited amplifier plug pin out for those who dont have the mark levinson package. Hope this can help some members.
Old Oct 16, 2022 | 08:06 PM
  #55
oldcruizy's Avatar
oldcruizy
If there's anyone still around from this thread, I'm wondering if I could get a technician to wire in an Aux input straight to the amp (2007 rx 350 ML system doesn't have one at all) and wire the amp so that if there's a signal coming from the Aux input the amp powers up, so that I can play sound through the amp and speakers from an Aux device without the keys in ignition....anyone know?
thanks
Old Oct 17, 2022 | 06:16 AM
  #56
r2digital's Avatar
r2digital
https://gromaudio.com/store/aux1_ada...tereo-kit.html
This is probably your best and easiest solution although it will probably only power up with the ignition on and not accessory
Old Oct 17, 2022 | 01:28 PM
  #57
oldcruizy's Avatar
oldcruizy
Thanks, that's not gonna cut it for me. Wondering if we could somehow tap into the wires going into the ML amp under the back seat to add an Aux input that way. This is proving more difficult than I first thought
aWorkOfArt
RC F (2015-present)
18
Feb 6, 2025 09:36 PM
vstyle444
Mar 13, 2016 08:03 AM
Sxy Lexy
Nov 20, 2009 10:33 AM
Sxy Lexy
Canada
Nov 19, 2009 12:16 PM
silverone
Sep 6, 2006 11:30 AM
