Master Window Switch Problems
Old Apr 18, 2025 | 02:22 AM
ProblemIS's Avatar
ProblemIS
3rd Gear
Question Master Window Switch Problems
I finally signed up and unfortunately my first post will have to be about the time I messed up my $1000 master window switch
In short, I tried to piggyback an ambient lighting strip power cable (negative and positive leads) off of the cable that runs into the switch.
From then on, none of the buttons work. I've already checked the fuses with a multimeter and everything is fine.
The interesting part is that when I was checking the board with a multimeter while it was plugged in and the car was running, I managed to roll down the driver side window, so I assumed it was just a problem with the board.
I ordered an OEM replacement off eBay but it still doesn't work so now I turn to you guys for any input and advice.
Also, I know I messed up and it was a really stupid thing to do. I clearly overestimated my abilities.
Old Apr 20, 2025 | 05:48 PM
playboyjay's Avatar
playboyjay
4th Gear
hey man ever figured it out i’m running into this issue now any help would be appreciated
Old Apr 21, 2025 | 05:44 PM
ProblemIS's Avatar
ProblemIS
3rd Gear
I'll call and book it in with an auto electrician. If they figure it out, I'll let you know.
Old Apr 21, 2025 | 09:25 PM
playboyjay's Avatar
playboyjay
4th Gear
hey i figured it out the switch doesn’t get 12 volts constant to the switch so go strait to the motor plug and it will be fine i got all my functions back like auto windows and all of them started working you may have to reset the others but holding down then holding up for five seconds hope this helps.
Old Apr 22, 2025 | 03:27 AM
ProblemIS's Avatar
ProblemIS
3rd Gear
I don't really understand what you mean/what the fix was can you please elaborate?
Old Apr 22, 2025 | 05:54 AM
playboyjay's Avatar
playboyjay
4th Gear
so instead of grabbing power from the window switch grab power from the plug that goes in to the window motor it self the switch doesn’t get enough power to power itself and the light but the motor gets a lot more hope this explains more
Old Apr 26, 2025 | 10:08 AM
Viperx's Avatar
Viperx
Easier to grab power from further down the switch… my car has ambient lighting but I tapped into the 12v for headlights and ground (headlights on = additional ambient on bc if I tapped into the ambient itself I got an issue of the power cutting in half going from P to D) but for me it’s not like Im gonna be able to see my ambient during the daylight anyways
WillDrivesAnOldRx
Dec 14, 2025 07:16 PM
stoney1997
Apr 17, 2020 05:23 AM
gs300_94
GS - 1st Gen (1993-1997)
May 19, 2010 06:55 AM
Leexus
Aug 8, 2006 04:48 PM
