Catalytic converters need to be changed
Old Nov 25, 2024 | 02:41 PM
jgscott's Avatar
jgscott
Originally Posted by Salman90
Spark plugs replaced and throttle body was cleaned last year. Currently I am getting 13mpg without pushing the car. My RPM barely ever goes more than 4. Do you recommend recharging the spark plugs and seeing if it makes a difference. Oil change is not due for another 1500 miles. I do regular oil change every 5000miles
Did you se Lexus plugs? Also a lot of Fake Lexus plugs being sold as out there.
Old Nov 25, 2024 | 05:16 PM
NYIS300awdFS's Avatar
NYIS300awdFS
Crazy but true, I purchased my plugs at the Toyota dealer.
Old Dec 20, 2024 | 05:06 AM
Salman90's Avatar
Salman90
Update:
after changing gas stations, using chemical cleaners for catalytic converter and changing the PCV valve, the car is back to its original self. The lagging acceleration and the smell is completely gone.
Old Dec 23, 2024 | 05:07 AM
Bearcats98's Avatar
Bearcats98
What about Shell gas could be a potential issue? I use shell as its Top Tier in hopes of longevity and no cleaning should be necessary.
Old Dec 23, 2024 | 06:09 AM
Salman90's Avatar
Salman90
I genuinely don’t know. Someone suggested it and I am trying it out. It could just be the chemical cleaner and changing the PCV valve.
Old Dec 23, 2024 | 11:52 AM
NYIS300awdFS
I also use shell 93 on my Is300 and my WRX, I’ve never had an issue with their fuel. Unlike a local Mobil that discounts their fuel, my tuned wrx detonates and pulls timing with that fuel, clearly it is not 93oct as it is labeled. Meanwhile with the local Shell 93 the WRX makes all the power without any issues whatsoever. I’m not saying every Mobil Station cheats, my local one does.
Old Dec 24, 2024 | 06:11 AM
brian3is's Avatar
brian3is
Here in my area, I can only use up to 91 octane at Shell. So that's what I stick with. Car is a 2016 model that was abused with 87 gas from the prev owner for 4 years. After multiple uses of cleaners, its A1 at 123,000 km. I'll change the original sparkplugs and PCV valve on my next oil change.
Vtwinhouse
Dec 31, 2022 02:43 PM
Notes671
IS - 1st Gen (2001-2005)
Aug 26, 2020 06:15 PM
LilMan23
Feb 10, 2012 03:19 PM
IS*Supra
Oct 3, 2011 05:39 PM
DanoIS300
Apr 17, 2008 02:21 PM
