Auto folding mirrors
Old Jan 16, 2024 | 10:50 PM
  #31
we1rdoo's Avatar
we1rdoo
Originally Posted by LexoticJ
Did you ever get this install completed?
not yet, my aim is to make it work with OEM switch if possible, if it is not the case then I will follow the same way as George plans, so called Honda method
Old Jan 20, 2024 | 07:33 PM
  #32
OCJACKAL's Avatar
OCJACKAL
Originally Posted by we1rdoo
damn mate, you are lucky that you have found matching color mirrors the second harness is for 360 camera, don't worry about it. I talked one of the guy in the dealership and he told me that most probably mirrors itself will be different in terms of view, because their driver side mirror is meant for our passenger side and vice versa, if this is the case, will have to disassemble your factory one and swap the mirrors, I can confirm that green and blue wires are for folding/unfolding, tested it on my Japanese mirror as well which is for 2021+ years model.
just to verify, the blue and green wires in the
center of these pics are the folding and unfolding wires.. is that correct? I tried a 9v a the end of the harness and nothing is happening for me... im just trying to verify that these are indeed power folding mirrors lol
Old Jan 20, 2024 | 09:39 PM
  #33
Lex_Giorgio's Avatar
Lex_Giorgio
I can't tell from your picture, here's a zoomed out picture of mine.
It's these two wires (circled):
Old Jan 20, 2024 | 09:49 PM
  #34
Lex_Giorgio
Also, If you have the blue on + and the green on -, flip the wires around to see if it does anything (blue on - and green on +)
Old Jan 21, 2024 | 03:39 AM
  #35
we1rdoo's Avatar
we1rdoo
I have the same mirror and blue and green wires fold/unfold the mirror, I can confirm that
Old Jan 21, 2024 | 03:37 PM
  #36
OCJACKAL's Avatar
OCJACKAL
GOT IT!!!! finally got them to fold with a new 9v... apparently the one I was using didnt have enough power... Now I just need to actually install them lol
Old Jan 21, 2024 | 04:57 PM
  #37
Lex_Giorgio
https://youtube.com/shorts/yEmv4O5emtk?feature=share
Nice!! I was about to say, check to make sure your 9v isn't dead lol!
Old Jan 26, 2024 | 03:33 PM
  #38
OCJACKAL's Avatar
OCJACKAL
ok I got them installed...
but I do think I will need to swap out the driver side motor because the angle is off... also its works with the press of the button only, not automatically... everything was plug and play.. didnt even need to do the 3 relay honda wire method...
one issue I am having is my park assist is disabled and I am getting flashing lights on the dash saying such. not sure why yet.. also the mirrors from Japan had an extra set of wires compared to the US edition..might be why im having an issue with the park assist.. still trying to figure it out.
here's a pic of the switch I picked up...
Old Jan 26, 2024 | 03:52 PM
  #39
Lex_Giorgio
That's why you can't go wrong with the Honda way... looks cool though!
Old Jan 26, 2024 | 07:45 PM
  #40
OCJACKAL's Avatar
OCJACKAL
looks like I just needed to drive it for a minute.. the warning lights when away and my sensors seem to be working properly
Old Jan 26, 2024 | 09:09 PM
  #41
Lex_Giorgio
Did you take a photo of the part number of the switch?
Old Jan 26, 2024 | 09:11 PM
  #42
Lex_Giorgio
Also, did you run any new wires at all?
Old Jan 26, 2024 | 09:27 PM
  #43
OCJACKAL's Avatar
OCJACKAL
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
this is the link to were I got the switch.. and no new wires were ran.. direct plug in. only issue is the angle of the driver side mirror is off a little bit. but I think when i swap the insides of the mirror, it should be fixed.. at least I hope so.. Also as a reminder, the auto button on the switch does not function as intended.. i mean the button physically works, but does not automatically fold the mirrors when the car is turned off..
Old Jan 26, 2024 | 09:48 PM
  #44
Lex_Giorgio
Thanks for the info!
That switch won't work on my car, it's a 20 pin, I have 22 pin (no memory seats in my car).
Old Jan 26, 2024 | 09:56 PM
  #45
Lex_Giorgio
Did you check to see if your memory seats work?
If so, you lucked out on everything!
