Missing heated steering wheel feature
Hello everyone,
First time posting on this forum site and looks like a great community. I have a 2015 IS350 F-Sport.
I just found out today that the F-Sport package for the 2015 model was supposed to come with a heated steering wheel. However, I do not have the button for it. I have everything else the package is supposed to come with. Why would this one feature not be present? Is it possible that my car has the functionality for the heated steering wheel and just need to get a button installed?
I believe, it was part of the cold weather package. At least, that is how it is both on my 2016 RCF and the 2019 IS350 F-Sport. Both of them have heated steering and was included as part of the cold weather package. It is a separate option. It was not offered in warmer climates, I assume.
Never heard of it being added on, I'd assume you'd have to get a new steering wheel which has the heat coils in the steering wheel, plus button, plus wiring?
You’d need the correct wheel, clockspring, and console button. The wiring is there, it’s all plug and play once you get those 3 items.
Hello everyone,
However the clock spring is the same (for heated and non-heated), part #: 8430853040
I'm 99% sure that all you have to do is change the steering wheel (along with the buttons on the wheel itself, part #: 8425053110C0) + add the button on the center console switch panel (part #: 84752-24040)
Update:
It's plug and play, no extra wire needed.
https://youtube.com/shorts/I__hLnWhosY?feature=shared
As far as I know, this connector should be plugged in a spiral cable assembly that is different for "base" models and the ones equipped with heated steering and pre-collision system.
The difference is an additional slot for this very connector.
What I was able to find is that to retrofit heated steering to my vehicle (2017 200t F Sport) with no lane keep nor ACC, one needs:
- heated steering wheel (WHEEL ASSY, STEERING - 45100-53471-21),
- central control panel (SWITCH, REFRESHING SEAT - 84752-24040)
- spiral cable assembly (CABLE SUB-ASSY, SPIRAL W/SENSOR - 84307-53040)
6speediroc
Apr 6, 2018 11:22 AM
