Check Engine Light after INVIDIA midpipe install
Hi so I installed my INVIDIA midpipe on my 2012 Lexus IS350, brand new the midpipe is brand new. As you know, there are no cats with this pipe. So after installing the midpipe and turning on the car for the first time, the car shuts off. So I turned it back on and I noticed I had a check engine light on. Ran through the codes and got P0031 P0051 and a few others related. I couldn’t rev the car to the max rpm I couldn’t pull the car that when the pedal is to the floor the car doesn’t wanna go. Trac is off and everytime I start the car I gotta start it twice as well as rpm’s are low when idle. From others experienced and from what I’ve seen and heard that no other with the same setup has encountered a problem like I have.
As a favor to those who might help, please post all codes AND their meaning to save us from doing your work! Nothing personal, but we shouldn't be looking up every code for someone else's problem.
That said, it's likely a bad connection or a wire broke that powers the sensors. Do double check all work performed and unplug and replug both o2 sensors. Maybe you find the fault.
babiibryan
Mar 11, 2024 10:29 PM
project350
Apr 7, 2015 08:47 PM
GTX780SLI
Oct 25, 2014 11:36 PM
chi123
Performance
Mar 19, 2011 10:18 PM
