Is250 engine fit is220
Old Jun 10, 2022 | 11:37 AM
Seanyg93's Avatar
Seanyg93
8th Gear
Default Is250 engine fit is220
Hi guys as the head is starting to have issues in my car, has near 200,000 miles so I’m happy enough it made it this far. But was considering doing a engine swap and putting a is250 engine in while I was at it. Just wondering has anyone done it, or what would be required I assume gearbox and diff probable different but as in fitment and general things that would need to be done just said I’d through it out there any help greatly appreciated
Old Jun 13, 2022 | 11:59 AM
2013FSport's Avatar
2013FSport
I'd venture to guess it's just not worth it.
Engine, transmission, potentially rear diff, all the mounts, ECU, wiring harness, potentially radiator and cooling fans, fuel tank and fuel pump, maybe the lines and all the evap equipment, full exhaust. I could go on....
GL
You basically need a donor car
Old Jun 13, 2022 | 02:32 PM
Ultra4's Avatar
Ultra4
If it's a manual transmission, I believe the vehicle is completely agnostic of the ECU outside of the neutral start switch and throttle cut from trac. The only "major" hangup I can currently think of would be adapting the fuel system to gasoline, which you can do with OEM parts or with an aftermarket inline pump. IIRC, the high-pressure fuel pump on the *GR engines wants nominal 50PSI supplied to it.
If it's an auto, I'd want to swap in an engine/trans combo that's been mated since the factory. It shouldn't be impossible to find a 3GR-FSE with a transmission attached; you can join the DIY IS300 coolguy club.
Katracho
Jul 10, 2020 08:32 AM
07is4GR
Apr 28, 2017 10:56 AM
Karpal
Mar 16, 2016 08:16 PM
ozzy250
May 10, 2013 09:33 AM
