Power Steering
Old Jun 22, 2021 | 09:50 PM
AlexRB's Avatar
AlexRB
Default Power Steering
After we had a massive rain storm that I drove home in, the next morning when I started my car the steering would shudder in notch like intervals and it was very hard to steer. The p/s light was not on but it was really bad, I had to like fight with the steering wheel to turn, I did some research and some people said that all I needed to do was clean the steering control module connections. Well while I was driving to the auto parts store to get the cleaning supplies my p/s light came on and I lost power steering. After I came out the store and turned the car back on the light was back off and I had the hard notch like steering again. I cleaned the steering control module and steering rack electrical connections and added dielectric grease but that didn’t do anything at all. Now I’m thinking I need to buy a new steering control module? Or should I buy a new steering rack, or both. Im just not sure what to do and would like any suggestions, thank you!
Old Jun 24, 2021 | 01:08 PM
MikeFig82's Avatar
MikeFig82
It's hard to say. Do you have any codes present?
Maybe remove the grease, and reclean the connections. You shouldn't have to use grease. The connections have a good water tight seal.
Make sure none of the pins have corrosion. About how old is your alternator?
Old Jun 24, 2021 | 01:23 PM
lockedlex's Avatar
lockedlex
I have my EPS from before I switched to my ISF module. PM me if you do end up needing to replace yours, mine might work. Also, I've got a 2014 C, so it's probably an improvement in steering feel over the earlier ones.
Old Jun 25, 2021 | 12:42 PM
AlexRB's Avatar
AlexRB
No codes no check engine light no power steering light; which makes this all harder to figure out what the issue is. When I cleaned everything none of the pins had corrosion they all looked good, and I had the alternator replaced in January .
Old Jun 26, 2021 | 09:33 PM
ncatona's Avatar
ncatona
If alternators good, then check the battery and see how it is.
Old Oct 4, 2023 | 01:50 PM
trdblackis's Avatar
trdblackis
Veteran: Army
Code c1554 is the P/S ECU and c1555 is the rack. I would start by checking the connectors on the rack.
Old Oct 4, 2023 | 07:52 PM
ELexis's Avatar
ELexis
Perhaps an issue with the 80A fuse PN: 82620-30170 (located in the fuse box under the hood near the battery) , per 2013FSport's reply # 5 here;
P/S light + power steering failure
https://www.clublexus.com/forums/is-...-now-what.html
Or maybe defective / loose electrical connector on the steering rack (SC- 1st Gen shown circled in photo below);
Old Oct 5, 2023 | 08:41 AM
2013FSport's Avatar
2013FSport
If said water was all about, pull the splash shield and remove the inner boots next to the rack and see if water entered the R&P. That's where I would start.
PS You'll need replacement clamps and the tool to install them. I guess you could remove the outer clamps and squeeze the boot but it would have to be completely full of water for something to com out.
@MikeFig82 IIRC you had your rack out for bushings? Do you recall seeing a vent on the rack?
OP - how deep was the water?
As for the 80A fuse, there would be no assist if that pops.
Old Oct 5, 2023 | 09:11 AM
2013FSport's Avatar
2013FSport
Dude, that's hydraulic R&P... Not the same. But ya, OP said they checked connections.
And honestly dielectric grease is fine. Ensure the flavor was non-conductive.
Old Oct 5, 2023 | 09:16 AM
Bichon's Avatar
Bichon
Interesting discussion, but be aware that this thread is more than two years old, and the original poster hasn't been here since July 2021, so I'd be surprised if he responds at this point.
Old Oct 5, 2023 | 09:46 AM
MikeFig82's Avatar
MikeFig82
@2013FSport
I don't recall seeing anything remotely to be a vent.
Yes this thread is a revival.
Old Oct 5, 2023 | 11:36 AM
2013FSport's Avatar
2013FSport
lol.... hate it when that happens. Someone recently dredged up an 11 year old post. Added no value to it (a comment to help) and for what reason, Idk...
Usually I keep track of that stuff. Oh well.
Old Oct 5, 2023 | 11:40 AM
2013FSport's Avatar
2013FSport
@2013FSport
Thanks!
I guess we can't rant about this thread if there's no vent hole!
haha!
Old Oct 5, 2023 | 02:50 PM
ELexis's Avatar
ELexis
Yeah, understand it's a photo showing hydraulic power steering rack and pinion (not electric). Photo was just to provide an example of steering rack connecter / location (had easy access to the photo).
DMike
Jul 29, 2023 01:24 PM
Ab175
GX - 2nd Gen (2010-2023)
Apr 2, 2021 08:38 AM
WILLIAMBLR
Jul 1, 2018 03:08 AM
gdave
May 24, 2010 08:06 PM
