RPM instant drop
My 2007 IS 250 instantly drops to 1k RPM after I let off the gas. I can rev to 4k RPM and it'll go without hesitation, but once I let off the gas it drops back to 1k, whenever the car idles it sits at around 500-600 (warmed up). I got a P0172 code three days ago, I went ahead and replaced my MAF sensor and cleared the code but my RPM still instantly drops, spark plugs and oil were replaced 1000 miles ago. Any help is appreciated! Thanks.
My 350 never cold idles above 1400 even when below freezing. On a 65°F day it bumps to 1100, then settles 900 in minute, once moved from the parking spot it settles at 680 after maybe 3 to 4 minutes of run time.
OP, is it still throwing codes? Have cleaned the MAF sensor with MAF approved cleaner?
If yes, start listening for vacuum leaks as suggested.
I'm still working on my IS's idle speed. It's 1.5K to 1.2K after a cold start. It eventually drops down to 1K. I've never seen it idle less than 1K even with the AC on. I'm thinking vacuum leak but I have no codes.
Not directly but I did run a full can of STP GDI cleaner through it to get rid of the carbon buildup. I guess I could get some cleaner and soak the plate area.
