Need help identifying part
Old Feb 20, 2021 | 10:36 AM
ArmorOfG0d's Avatar
ArmorOfG0d
Default Need help identifying part
Hello,
I'm currently replacing the valve cover gaskets. I took off the intake manifold to change those gaskets and clean the carbon build up while i have everything taken apart. I found this part laying in the engine bay and I'm unsure where it goes or what it is. It doesn't look super important but I'm hoping someone can identify it so I can return it to its proper home. Thank you in advance for any help.
Car is: 2007 Lexus IS 250
Old Feb 20, 2021 | 01:23 PM
MikeFig82's Avatar
MikeFig82
I've taken off my lower, and upper intakes multiple times. I have never encountered something that looks similar to that piece.
Old Feb 20, 2021 | 01:36 PM
ArmorOfG0d's Avatar
ArmorOfG0d
Copy. This peice was definitely not part of the intake manifold (IM) /valve cover (VC) job. I don't know where it came from. Is it something unrelated to the IM/VC that maybe fell off during disassembly? It looks it could be a thumb screw cover for the switch/sensor that tells you whether the hood is open or close. But I looked all around the hood perimeter interface and can't seem to locate where it fell off.
Old Feb 20, 2021 | 06:29 PM
Petet's Avatar
Petet
Close match
Old Feb 20, 2021 | 09:47 PM
ArmorOfG0d's Avatar
ArmorOfG0d
Close indeed. Any more info on the part number, or what it might belong to?
Old Feb 21, 2021 | 12:32 AM
lockedlex's Avatar
lockedlex
That's definitely not a Toyota/Lexus part. It screams aftermarket. Could have been left in the bay by accident after someone else worked on it. Could also be an aftermarket kill switch cover or something like that.
Old Feb 21, 2021 | 12:59 AM
Dealarr's Avatar
Dealarr
Originally Posted by ArmorOfG0d
Hello,
You sir, I like your name.
Old Feb 21, 2021 | 01:20 PM
Jeeves250's Avatar
Jeeves250
That doesn't look like a Lexus part. The brass on that piece makes me think it's something to do with washing a car, like a pressure washer accessory or something that someone in the past dropped in your engine bay and was never able to find it.
Old Feb 21, 2021 | 01:47 PM
ArmorOfG0d's Avatar
ArmorOfG0d
Roger that. I'm glad my initial suspicion that it was not important was correct. Thanks for confirming fam. However, after putting it back together multiple times, I have bigger issues... I'm going to start another thread :-/
Old Feb 21, 2021 | 04:40 PM
2013FSport's Avatar
2013FSport
It's a switch condom likely off from someone's test equipment. When was it in the shop last?
Old Feb 21, 2021 | 05:27 PM
ArmorOfG0d's Avatar
ArmorOfG0d
Thanks. A few years ago.
Once at a Lexus dealership to do a full inspection. Then shortly after that a mom & pop mechanic shop to get new tires, new disc brake pads, and bleed the brake lines.
Old Feb 23, 2021 | 06:23 PM
bazzle01's Avatar
bazzle01
Its a water proof switch cover. Someone has dropped it there by mistake.
Parminder7
Feb 21, 2021 01:23 PM
fstlane
GS - 1st Gen (1993-1997)
Feb 2, 2011 04:44 PM
mark458
Sep 17, 2009 07:38 PM
yusych
May 10, 2007 06:02 AM
Twirl
Apr 22, 2006 10:53 AM
