high idle
Old Jan 18, 2021 | 06:15 PM
jjbarcinas's Avatar
jjbarcinas
Default high idle
2011 is250 idle issue. Throttle body was replaced and now scanner is reading throttle position at 51%. I read that it should be somewhere around 14. Is there a way to adjust this or does a trip to the dealer the only option.
Old Jan 19, 2021 | 08:06 AM
MikeFig82's Avatar
MikeFig82
What caused the TB to fail? This is the first of I heard of one failing.
Old Jan 20, 2021 | 07:51 AM
2013FSport's Avatar
2013FSport
51%, how high is the idle, like 4k??
It must have some codes. Please report what they are! As noted above, it must be something else.
Old Feb 1, 2021 | 10:34 PM
Guy24's Avatar
Guy24
Had a high idle on my 08 IS 250 along with some shaking but after changing the spark plugs it was gone. Don’t know if that helps in any way?
Old Feb 2, 2021 | 04:50 PM
Protholl's Avatar
Protholl
I had a high idle two nights ago - 2300 to 2600 for three or four minutes. It was very cold but I didn't expect it. This afternoon I started her up after replacing the steering and she went up to 1500 but then it fell back to 1100 pretty fast. This was with the local temp 51F. I still don't know why the previous start was so high an rpm idle. No codes when I checked it.
Old Feb 2, 2021 | 05:46 PM
Jeeves250's Avatar
Jeeves250
Have you tried disconnecting the battery, waiting a couple of minutes, and plugging it back in? That resets the ECUs and may recalibrate the throttle sensor.
xitr097
Jul 24, 2023 12:29 AM
airlaird
RC F (2015-present)
118
Aug 4, 2021 08:35 AM
PhantomCS
Nov 21, 2019 05:04 PM
Slickcam
GS - 1st Gen (1993-1997)
Mar 5, 2016 03:03 PM
qha_vn
Nov 17, 2008 12:23 PM
