fuel level sender problems
Old Jun 20, 2020 | 05:10 AM
FirasAsher's Avatar
FirasAsher
Default fuel level sender problems
Dear friends , this subject has been discussed many times , I want to add my experience and I hope it will be helpful for others.
my fuel gauge range was 45% - 95% ,I opened the hole which is located under the driver rear seat and pull the fuel pump assembly that contains the fuel level sender .I made cleaning and maintenance and measured the variable resistor ( found ~ 98 ohms) but nothing changed then a friend told me there is another sender located in a hole under the passenger rear seat and that is correct there is a sender without a pump I also cleaned it and maintained it and measured the variable resistor ( found ~ 178 ohms) .then everything went better the gauge range came down to 0% .
I have collected the below diagram showing the senders connections.
Thanks and good luck to all
Firas
fuel level sender wiring diagram
brkenlexus
Jul 19, 2021 12:35 PM
davinciii
Performance
Nov 16, 2016 05:57 AM
RRocket
Jun 11, 2016 03:58 PM
Blk97SC300
Jul 15, 2008 06:17 PM
morris
Dec 22, 2006 03:18 PM
