Bad Experience with Maxlife Full Synthetic ATF
Old 10-09-20, 02:54 PM
D0nat
D0nat's Avatar
Which model do you drive?
Old 10-09-20, 11:29 PM
jizz4jazz
jizz4jazz's Avatar
2007 IS250, Its at 150,000 Miles now on MAXLIFE ATF, Transmissions smooth, and shifts like butter. I went to 140,000 without changing the fluid, anything would have been better than the fluid that was in the trans.
D0nat (10-10-20)
Old 10-10-20, 04:00 PM
D0nat
D0nat's Avatar
Thanks for your feedback but I’ve just bought 12liters of Toyota WS before I opened this tread again))) Tomorrow morning I’m going to service it with special machine. On 40000km Toyota WS was renewed particially with filter and now there’s 80000km on a clock. Seems it’s time to make a complete fluid change.
Old 10-10-20, 07:49 PM
IS250DIYER
IS250DIYER's Avatar
I replaced the trans in my 06 IS250 last year. I didn't get fluid thill the last minute and bing a weekend the Toyota dealer was closed so I went with max life because I wanted so bad to see the car drive again. I didn't want to use maxlife but I also didnt want to wait. The fluid worked but right off the bat I could tell the car didnt like it. Over the next week I'd say I did 8 drain and fills and spent around $140 on fluid. I knew I wouldn't get all of the max life out but I sure did try. Overall Toyota WS is what I would say to use. I will always go with OEM in a car or trucks transmission.
Ashton H.
Old 10-12-20, 08:37 AM
D0nat
D0nat's Avatar
As I mentioned above I made a complete change of ATF WS in my transmission using special machine.
Partially changed ATF at 40000km were dark red but not burned, so it's definitely need a change.
I bought 12 liters of Toyota WS, and only 10.5 liters were used to perform a change.
Also memory reset was done. My mechanic told me to drive first kilometers slow, because transmission computer should be adopted.
So right now I can't say that I feel the difference before and after ATF change, maybe AT operates a lil bit smoother.
Old 10-12-20, 07:15 PM
DJPsystems
DJPsystems's Avatar
I have switched to Maxlife ATF and I have had no problems. I first dropped the pan and changed the filter. I then did 3 drain and fills. Transmission shifts normally. I don't see what all the fuss is about.
D0nat (10-13-20)
Old 10-13-20, 03:45 AM
D0nat
D0nat's Avatar
My mechanic told me that he made so many ATF changes on these cars, and saw that people used different ATFs and not only WS-type fluids, and transmissions did not died even with dexron III ...
I think it's not good idea to use such a different viscosity but any LV fluid, which named WS-type, should operate without any issue.
BayAreaLex
10-23-19 09:40 PM
terminater
08-15-17 04:57 AM
norman52
05-25-08 08:13 PM
gadgeeets
Performance
04-04-07 07:10 PM
Quick Reply: Bad Experience with Maxlife Full Synthetic ATF
