Part number identification
Old Mar 8, 2020 | 01:02 PM
mthornto88's Avatar
mthornto88
Default Part number identification
Does anyone know this part circled in red ? I tried searching but can't seem to find it. One of the two wires is cut. I had a mouse in my car it seems and it ate through the foam on the cover and this wire. It comes out from the long wire running down the middle of the engine bay.
Old Mar 8, 2020 | 03:49 PM
sinister2c's Avatar
sinister2c
those plugs generally aren’t replaceable items from dealer. Only options are aftermarket or junkyard.
Old Mar 8, 2020 | 05:14 PM
mthornto88's Avatar
mthornto88
Yeah I figured that. I am looking for the plug type so I can check for one on eBay.
Old Mar 8, 2020 | 06:48 PM
mthornto88's Avatar
mthornto88
Doing some more research it looks like part number 90980-11246. The ignition coil fuel injector plug.
I have a 2012 is250 fsport RWD. Does that sound right?
Old Mar 8, 2020 | 07:49 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
These items actually are typically replaceable from the dealer for Toyota/Lexus/Scion.
Part number for this connector is 90980-11156. Note that this is just the plastic connector, to repair the wire you need 82998-12440 (2 per connector).
Jeff
Old Mar 9, 2020 | 05:31 AM
mthornto88's Avatar
mthornto88
Thanks Jeff. The part you listed definitely looks like it. But when I look up that part against my car it doesn’t say it’s compatible. Should I be worried?
Old Mar 9, 2020 | 01:57 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
No need to be worried. Part numbers for connectors are not typically vehicle specific, and so most systems won't be able to tell you if a connector is compatible or not.
Jeff
Old Mar 9, 2020 | 06:31 PM
mthornto88's Avatar
mthornto88
Ok. I have ordered it. Appreciate the help.
DropD
GX - 2nd Gen (2010-2023)
20
Sep 14, 2019 12:49 PM
biosurfer1
May 24, 2019 01:38 PM
Slickcam
GS - 1st Gen (1993-1997)
15
Feb 4, 2016 03:15 PM
WeisISF
Nov 13, 2012 01:21 PM
bryan767
Apr 19, 2011 10:00 AM
