Thinking about getting the E85 tune
Old Oct 12, 2019 | 08:22 AM
Thannp's Avatar
Thannp
Default Thinking about getting the E85 tune
Hi guys.
I talked to a reputable tuner here in thailand. He said he had done multiple E85 tune on the 86 and BRZ with stock engine component. No fuel pump/injector upgrade and provide great result about 20WHP more than pump gas and the engine does not run lean.
i think he use 86/brz as an example cause they are DI engine
He is also saying that. It is possible to tune an E85 map on IS350 with stock fuel pump and injector and will have proper A/F ratio and should expect more than 20WHP when compare to the E20 map I am having.
We know that our Direct injector size is almost 1000cc and I can confirm it is the same injector that use in LS460 engine. The high pressure fuel pump in the engine bay is also the same but on the LS460 they have 2 of them.
I have easy access to E85 so that will not cost me any problem.
Only thing i am worry about is I dont think anyone ever done this on a 2gr fse engine before even RRracing tune i saw only goes up to E40 blend.
Do we know if they use stock injector for their supercharger kit with E40 blend? If that is the case it maybe possible that the is350 stock fuel system could provide sufficient flow rate for E85 tune which require about 30% more than pump gas
Currently my car got 317whp with E20 on the last dyno run if I could add 25whp more it would be awesome!
All comment appreciated
thanks!
Old Oct 14, 2019 | 08:22 AM
Gville350's Avatar
Gville350
I myself have not read of any members having a complete E80-E85 tune...yet. Will you have enough fuel flow to deliver that E through those DIs...that is the mystery question. What I would do would be to install an appropriately placed bung into the exhaust, install a quality WB O2 kit, and monitor your AFRs closely while tuning. No "tailpipe sniffers".
Old Oct 14, 2019 | 06:49 PM
Thannp's Avatar
Thannp
thanks for the reply
RR-racing confirm that the injector will supply sufficient fuel for the tune but they say it might not make more power than a E30 tune.
Where I live is very warm. During the day time its reach 100F easily. E85 might help it run cooler and smoother if not faster.
Anyway, my tunner say he would not charge me if I could not feel that the new tune is better.
Old Oct 15, 2019 | 08:03 AM
Gville350's Avatar
Gville350
You're right about it running cooler and it'll help "clean" the engine more. I used to have a boosted Honda Civic on E83-E85 and it also netted larger torque figures than a compatible 93 pump gas tune.
I thought it funny that you mentioned about being somewhere where it is very warm, but yet your location is "Minnesota". LOL! I know you're overseas, but I forget where.
I'd say get a E30 tune dialed in, and then try out a E85 tune and see what happens. I'd still install that wideband to avoid leaning out too much and avoid pre-ignition.
Old Oct 15, 2019 | 11:28 AM
Thannp's Avatar
Thannp
Bangkok, Thailand haha.
I used to study in minnesota i still go back there sometimes
any recommendation for wideband sensor and gauge? Wanna keep the stock looking interior have to figure out where to install it.
thanks
Old Oct 16, 2019 | 09:25 AM
Gville350's Avatar
Gville350
That's right! Yep, very hot.
Yeah, I've always loved the Innovative MS products : https://www.innovatemotorsports.com/
Old Dec 3, 2020 | 09:34 AM
bob256k's Avatar
bob256k
What mods have you done to your car, other than the ported lower intake
Old Dec 3, 2020 | 09:55 AM
Thannp's Avatar
Thannp
these are my current mod power wise
Sard high flow filter, stock box with Fspot mod,SARD intake tube, ported lower maniflod, ppe header, Nvidia mid pipe with custom highflow cat, surugaspeed resonator and suruga speed loop sound exhaust.
I also have a custom tune E85map by a local tuner here in Thailand netting 331WHP
https://www.clublexus.com/forums/sho...7&goto=newpost
ETHANRA64
Jun 3, 2014 12:39 PM
frankjames
RX - 1st Gen (1999-2003)
Sep 20, 2009 08:59 PM
j_version_
May 22, 2008 03:53 PM
Jasoneo5
Nov 8, 2004 04:41 AM
roenick7
Jul 3, 2002 11:52 AM
