Light Bulb/LED replacement Guide
Great write-up!
I wanted to replace the stock halogen trunk light with an LED bulb. The one I bought from PrecisionLED was too long to fit so I had to put the stock halogen one back in.
What is the length of the LED bulb you used for the trunk light? I believe this is the DE3022 bulb.
I see on VLEDS and iJDMtoy's websites that they sell DE3022 in 29mm instead of 31mm. Will 29mm work? The stock halogen one seems like it's even shorter like 26-27mm.
I used this 31mm Festoon bulb: https://www.ebay.com/itm/5-PCS-4SMD-...72.m2749.l2649
It was a little snug, but fit just fine. I'd guess 29mm wouldn't be an issue either.
mrsardar
Feb 25, 2018 11:57 PM
