Alternator decoupler pulley question
Old Dec 27, 2017 | 03:17 PM
thino's Avatar
thino
Default Alternator decoupler pulley question
I have a 2012 f-sport is350, and currently having the "chirping" sound coming from the pulley. I read a few threads on here claiming that if we removed the cap on it, we should be able to see some rust build up (https://www.clublexus.com/forums/is-...g-noise-2.html)
When I removed the lid from the pulley, I see tons of grease / gunk build up inside of it. I'm not sure if this is normal? Most pulleys I've seen are pretty clean. Correct me if I'm wrong.
Old Dec 27, 2017 | 09:39 PM
thino's Avatar
thino
Here's the actual video of the sound. Drove it around for about a 2-3 miles at around 50-70 mph and sound still sounds pretty bad. It just seemed to get worse after I opened up the cap and cleaned it out.
Old Dec 28, 2017 | 01:05 AM
synrgy350's Avatar
synrgy350
I replaced the pulley on my IS350, just buy the Lisle 57650 alternator tool on amazon and get a new pulley with it. It wasn't hard to do if you can turn a wrench. Got rid of the chirping noise for me, all quiet now!
Old Dec 28, 2017 | 02:15 AM
thino's Avatar
thino
Got it. That was going to be my next steps. Could i replace the pulley with the alternator still intact? Or would i need to remove the entire thing in order to disassemble the pulley.
Old May 4, 2023 | 02:22 PM
MikesLexo's Avatar
MikesLexo
Hopefully you're still active. Did you end up removal the whole alternator for this job ? Ordered but hopefully don't need to rip it out
Old May 4, 2023 | 02:27 PM
MikesLexo's Avatar
MikesLexo
Got an Litens OEM pulley with no instructions. Did you need to turn the pulley counter clockwise to loosen ? Thanks
Old May 5, 2023 | 10:46 AM
2013FSport's Avatar
2013FSport
Last post was 2017-12, I wouldn't count on it.
Have you deemed your pulley to be defective? Depending on the miles, if North of 125k mi I'd replace the whole thing w Denso reman and save yourself some headache. JM2C
Old May 8, 2023 | 01:10 AM
MikesLexo's Avatar
MikesLexo
yes, i read some forum to inspect for rust after removing the cap off the decoupler pulley. I found rust behind where I blew it out and relubed the system. Sound is gone and very happy. OAD pulley are recommended for replacement at 120k and since I already purchased the pulley for $30. Figure it wouldn't hurt trying to extend the ALT life. Charging is perfect at the moment beside the chirps that annoys me
Old May 8, 2023 | 02:09 PM
2013FSport's Avatar
2013FSport
Glad car decided to support this!
GL
Lzam
Jun 14, 2017 09:46 PM
robsotelo
Nov 17, 2011 02:44 PM
smokesgtp
Feb 6, 2008 06:46 PM
underpsi
May 6, 2007 12:21 PM
