remote distance falling
Old Sep 14, 2017 | 03:16 AM
ParDHarD's Avatar
ParDHarD
Default remote distance falling
I have a 2006 IS 250 AWD and the distance on the remote is getting worse on a daily basis. It seems like a battery is going bad, but I have 2 separate remotes and both have new batteries, so it's NOT the key fob. It seems like there is a similar battery in the car receiver that is going dead.
My guess is that I need to replace the receiver in the car. What can I check/replace besides the key fob?
Thanks!
Old Sep 14, 2017 | 05:10 AM
jr4div2's Avatar
jr4div2
When is the last time your car's battery was replaced? If it's been some years or not, got to you local autozone/advance/chief and get your charging system and battery tested. I've not had this problem on my IS, but I do have a Ridgeline and I noticed once when the same thing started happening, my battery in the truck was getting weak. I replaced the battery and BAM!, distance on my key fob came back.
Old Sep 14, 2017 | 09:25 AM
ParDHarD's Avatar
ParDHarD
If the voltage is dropping, that could cause range to drop, yet still be enough to start the car without any problems.
It's 3 years into a 7 year battery, so my guess is that it's good though.
But it certainly is possible, so I'll get it checked tonight...
Old Sep 14, 2017 | 09:39 AM
jr4div2's Avatar
jr4div2
There are several things that can cause a weak battery as you probably know. Your car is 10+ years old so the alternator or voltage regulator could be pooping out on you. That's why I suggested a full charging system check.
Old Sep 14, 2017 | 01:24 PM
ParDHarD's Avatar
ParDHarD
System checks out, everything is operating 100%.
I'm not sure, but I'd imagine even if I found a decent priced receiver replacement, I'd still need the dealer to program it into the system.
Old Sep 15, 2017 | 08:36 AM
sktn77a's Avatar
sktn77a
Let the dealer diagnose the problem before you go buying parts.
Yonny
Aug 17, 2018 12:30 PM
goya
Nov 3, 2014 04:54 AM
FLYCT
Nov 16, 2012 07:28 PM
cardenje
May 1, 2012 03:32 PM
Harold57
Apr 29, 2009 07:14 AM
