p1235 06 lexus is350
Old Aug 30, 2017 | 07:31 PM
mannyis350's Avatar
mannyis350
Default p1235 06 lexus is350
I recently changed the tranny and as soon as I start the car it turns on but wont pass 2k rpm like it wants to but it cant. THE CHECK ENGINE CODE IS P1235 FUEL PUMP FAILURE CIRCUIT I ALREADY CHANGED FUEL DIRECT HIGH PRESSURE THAT GOES ON TOP OF THE HEAD AND THE FUEL PRESSURE SENSOR PLEASE HELP !!!!:[
Old Aug 30, 2017 | 07:34 PM
Zmon's Avatar
Zmon
If the fuel pressure sensor was the culprit, the car wouldn't start at all, which I'm assuming you had that problem in the past and was the reason you replaced it.
You say you replaced the tranny. Did you double check hoses, lines, and electrical connectors were reconnected properly? Proper fluid level? Obviously if that code wasn't there before, I'd start looking to make sure no connections were frayed/cut on accident.
Old Sep 8, 2017 | 10:04 PM
mannyis350's Avatar
mannyis350
the car runs gears shift but the problem is the car is on limp mode, meaning it wont rev pass 2k .I checked the fuel pump seems likes it working but the filter is a bit dirty. I TOOK IT THE DEALER INSTEAD DAMM LEXUS.
Old Apr 27, 2022 | 02:57 PM
davidbusta's Avatar
davidbusta
i have the same symptoms and code on my 06 is350. I was reading that the driver fuel injection driver connections could have came loose and cause this code. So I checked the connections there and all the connections seem like they are still good. What else could be the solution to this?
DorianB
RX - 1st Gen (1999-2003)
Apr 20, 2019 04:56 PM
JohnCarter
Oct 14, 2018 06:34 AM
Moarpower
Sep 9, 2018 02:14 AM
fugaisi420
IS - 1st Gen (2001-2005)
Jul 30, 2016 08:08 AM
Lamprey
Apr 4, 2011 08:25 AM
