Touch screen not working?
Old Aug 10, 2017 | 06:17 AM
OKC06IS250's Avatar
OKC06IS250
Default Touch screen not working?
My touch screen is not working on my 06 IS 250. The screen comes on as usual but when I press I agree nothing happens. I can move from Climate to audio and so forth but nothing happens when I try and press the screen. I saw some post about this issue but they were from 2010.
Anyone have this issue? If so how did you fix it?
THanks
Old Aug 10, 2017 | 08:23 AM
andper10's Avatar
andper10
https://www.clublexus.com/forums/is-2nd-gen-2006-2013/610678-frozen-navigation-screen-fix-diy.html
Get a new digitizer on eBay - it is not much more than the circuit writer pen and much more likely to last long term. I removed my old digitizer with dental floss and a heat gun on low (hairdryer would work too) to loosen the adhesive. There was enough left that the replacement stuck in place fine. There is a YouTube video that walks through the whole process.
Old Aug 10, 2017 | 09:07 AM
AyRow89's Avatar
AyRow89
^^ What he said. Common issue on the 06-08. The ribbon connector for the digitizer is very flimsy and doesn't hold up well. Buy the digitizer and DIY. I did mine in less than an hour.
Old Aug 10, 2017 | 10:50 AM
OKC06IS250's Avatar
OKC06IS250
Thanks guys
If I buy a new screen does the digitizer come already connected?
thanks
Old Aug 10, 2017 | 10:55 AM
AyRow89's Avatar
AyRow89
Yes, typically.
Old Aug 10, 2017 | 12:07 PM
andper10's Avatar
andper10
Originally Posted by OKC06IS250
Thanks guys
thanks
As you mentioned the screen is displaying fine so I wouldn't bother to replace it - especially with a used unit since the digitizer would likely fail at some point in the future if it was not already replaced, leading to having to do all of the labor a second time.
Old Aug 10, 2017 | 04:49 PM
whitebeast's Avatar
whitebeast
you forgot one thing that aftermarket digitizer clarity is nothing near OEM. You will see the different right away when you install it
Old Aug 10, 2017 | 05:06 PM
BlckGhst's Avatar
BlckGhst
I used this video to help me fix the non-responsive screen on my 08
Old Aug 13, 2017 | 05:02 PM
cclar's Avatar
cclar
I guess this will help .
Old Aug 14, 2017 | 11:57 AM
mkeeney's Avatar
mkeeney
Since there are multiple digitizer screens available, it's not very useful to make a blanket statement like this. On top of that, the OEM screen has a unacceptable failure rate.
Please read the linked thread above for more info. From my post in that thread:
This is the digitizer I bought: ebay digitizer
It looks OEM after it was installed and works perfectly. There's no rainbow effect like some have complained about and the screen is easy to see.
This is the tape I used to secure it to the LCD:
"><img src=" /> ">
Amazon 3M tape Amazon 3M tape
Old Aug 14, 2017 | 04:44 PM
whitebeast's Avatar
whitebeast
Good luck with that screen. I did test it out and the clarity is not event halfway of the OEM.
I did see one aftermarket screen has very good quality from the clearly image to touch sensitive but i don't know where he got it.
Old Jul 18, 2020 | 09:03 AM
JohnBrown7's Avatar
JohnBrown7
Hi Guys. ( 2009 Lexus IS250)
I need your expertise and knowledge about my display.
I wipe my display with dashboard cleaner and after one day my display acted weird. display Showing and after that stop displaying. after 10 days display start work for a minute and stop again.
not noting showing again.
I have change all fuses and remove battery cable for a day and install again. noting changed.
I need your help.
Thanks
Old Mar 23, 2022 | 11:06 AM
Wh0pp3r's Avatar
Wh0pp3r
Sorry for bringing this back from the dead. but my screen is lit up white. but still able to input commands on-screen, as in i can switch from stereo and ac functions primarily because I remember where the on screen commands are. . can still see screen glitch to reverse camera when i go into reverse but screen is still white. ive read about "frozen screen" where is doesn't allow input commands.
just wondering if anyone can point me in the right direction.
Old Jul 17, 2022 | 11:02 AM
kenners's Avatar
kenners
1st Gear
Default Potential fix (fixed it for me!)
figured a fix that works for me. 100% free, no tools required
Old Jul 17, 2022 | 11:06 AM
Wh0pp3r's Avatar
Wh0pp3r
Instructional Video
negative unfortunately. Mine just goes white. Can still input commands, but stays white.
