2009 is250 passenger low beam problem?
Old Jul 22, 2017 | 08:33 PM
Castro2's Avatar
Castro2
Default 2009 is250 passenger low beam problem?
Recently replaced stock halogen lightbulb with a Kensun H.I.D conversion easy.
Now that I have brighter lights it's a lot more annoying that my passenger side casts but only a very concentrated beam of light. I tried installing the light bulb at different rotation with little luck.
They're aimed what looks to be good,don't know how to aim horizontally.im thinking somethi ng inside the housing aims it incorrectly?but idk
any ideas?
BTW it was the same before just more noticeable now.
Thanks in advance
Old Jul 24, 2017 | 09:01 PM
MikeFig82's Avatar
MikeFig82
any ideas?
Thanks in advance
Can you post some pics? It's just concentrated down to the ground? If so you need to adjust vertically not horizontal.
Old Jul 25, 2017 | 07:05 AM
Castro2's Avatar
Castro2
Thanks for the response.
It was but I raised it to as level as the driver side. It doesn't cast an even spread of light it's very bright beam instead a spread.
I will later tonight.
I'm thinking the housing is off somewhere..
Old Jul 25, 2017 | 10:33 AM
Bichon's Avatar
Bichon
The housing was designed for a halogen bulb. If them beam pattern was correct before you installed the HID kit, I'd think it more likely to be a compatibility issue with where the light source on the HID bulb sits in the projector vs. where it was with the original bulb.
Old Jul 25, 2017 | 10:55 AM
Castro2's Avatar
Castro2
It is actually the same beam as with the halogen, only I thought by placing new bulbs it would correct this. Didn't work it's just a brighter beam. Very odd and very annoying
Old Jul 26, 2017 | 05:58 AM
Castro2's Avatar
Castro2
Old Jul 26, 2017 | 07:27 AM
MikeFig82's Avatar
MikeFig82
Being where the car is they look too dim. Both sides should be brighter than that. Are they aftermarket or OEM?
Old Jul 26, 2017 | 01:21 PM
Castro2's Avatar
Castro2
I did lower the light filter on the camera to capture as best I could.. this picture doesn't fully show what I mean but the passenger side is not well blended. I also noticed that the driver side is not even noticeable. If I cover the passenger it's very faint.
Old Jul 26, 2017 | 01:23 PM
Castro2's Avatar
Castro2
Old Jul 26, 2017 | 02:05 PM
MikeFig82's Avatar
MikeFig82
Are you sure they are in the housing correctly. Insert your stock bulbs back in so you can get a feel of the way the bulb should be positioned. The passenger side & driver side mount in weird positions to begin with. Make sure all 3 bulb tabs go into the housing correctly. That's the only thing I can think of.
Old Jul 26, 2017 | 03:45 PM
Castro2's Avatar
Castro2
Original bulbs looks similar. As far as the projection. I'm going to play with the positioning...
Thank you
CodeMan
Jun 5, 2019 07:27 PM
80sHero
Oct 19, 2018 07:06 AM
harrykaw
Jun 28, 2016 05:53 AM
chino713
Jan 23, 2012 07:43 PM
stefnee
May 12, 2007 02:46 PM
