WHINING NOISE please help
Old Jun 14, 2017 | 11:06 PM
michael22's Avatar
michael22
Default WHINING NOISE please help
Hi clublexus fam,
this morning when I started my is250, I realised a loud whining noise. I have attached a video. I have read some forums saying it's normal but normally it is no where near as loud. Some people say it's the alternator whilst some says it's the belt. Has anyone had the same experience? What was the problem?
Thanks
Old Jun 15, 2017 | 04:29 AM
See5's Avatar
See5
You need to have the pulleys checked. Mine was the tensioner pulley causing similar noise.
Old Jun 15, 2017 | 05:31 AM
WhatYaGot's Avatar
WhatYaGot
Maybe the water pump?
Old Jun 15, 2017 | 06:41 AM
michael22's Avatar
michael22
what did you do to fix it? Did you have to replace anything? Also, I'm not sure if this will help, but the whining sound gets louder as I accelerate.
Old Jun 15, 2017 | 05:01 PM
sktn77a's Avatar
sktn77a
Doesn't sound like a water pump. Maybe an alternator? Tensioner? Pulley?
Old Jun 15, 2017 | 08:43 PM
Offspring's Avatar
Offspring
I replaced the water pump and the alternator and still have the whine. Next up is the tensioner pulley. I've had the whine for years and car drives no different than before
Old Jun 16, 2017 | 10:26 AM
jr4div2's Avatar
jr4div2
Another possibility? A/C compressor? Does it change when you switch the A/C on/off?
Old Jun 17, 2017 | 12:18 PM
whitebeast's Avatar
whitebeast
Yes, sound more like AC compressor
Old Jun 19, 2017 | 02:13 PM
Gville350's Avatar
Gville350
Swap out the accessory belt first and see if that helps. Definitely part of the accessory drive system.
Old Jul 4, 2017 | 12:38 AM
See5's Avatar
See5
Am really sorry and thankful I didn't listen to what the mechanic said at first! It was the alternator causing the noise, not the tensioner pulley.
Good luck
adriann829
Oct 27, 2016 05:32 PM
river
Mar 17, 2016 09:52 PM
lextout
Oct 27, 2015 10:10 PM
Ca1vN
Mar 16, 2015 01:43 PM
jersey1
Aug 6, 2002 04:11 PM
