VIPMotoz h7 Bulb question
Has anyone installed an LED headlight kit into the aftermarket headlights? My car came with the HID / AFS headlights. So im going to buy an h7 headlight conversion kit regardless. Is the LED kit a better option?
Any advice would be appreciated.
in my opinion. I prefer LEDs. They last longer and less prone to crapping out since you don't need a ballast. I have direct plug and play LEDs and they're awesome. Both HID and LED cost the same, in the end. So just take your pick. HID has color options but more prone to breaking and LED is only pure white.
i had HIDs and LEDs before. Currently using LEDs. If you install these bulbs, your AFS will no longer functions. it's just something you lose with this mod. Also, I've used H11 bulbs which I think if the correct bulb for our cars. But H7 might work also, I'm not sure. I just know most/all use H11 bulbs
A pic of your light will be helpful here.
OEM halogen using H11 but most of after market headlight using H7. As for HID vs LED, I refer HID due to the brightness of it. LED will give you the most accurate color temp but good HID kit won't disappointed you. I did test out Morimoto Kit and DDM tuning kit and very happy to both of them (DDM TUNING is cheaper)
A note for you.
doubt it. I have vipmotoZ aftermarket headlights and it's h11 hid bulbs that it comes with.
perhaps. Mines pretty old. A few years. But all bulbs are similar. Just some different relays and plastic mounting shapes
I just ordered my set and also thinking about either ordering HID or LED H7
I think I will go with HID Low beam and LED High beam H1. But am not sure how much LM on the LED will beat the halogen intensity.
Time to check VIPmotoz headlight discussion thread!
See5 (07-04-17)
mafpolo
01-18-17 03:54 AM
tofuprod
CT 200h Model (2011-2017)
16
06-03-16 11:12 AM
