Headlight bulb help
2015 is250 fsport
Looking to buy 6000K bulbs. What kind of bulb do I need to buy? Size? Brand?
Do i need to buy an HID kit or just the bulbs?
Any suggestions or links would be helpful thanks!
Thanks guys, I figured I was looking for D4S bulbs, and the phillips ultinon was my first option. Is there a way to tell if thats for sure what I need? i don't think I have LED lamps because they don't look LED. Also is the price of the Philips Ultinon worth the upgrade?
I believe Canadian F Sports are HID only, so the OP probably does have the HIDs. In the US, F Sports come standard with LEDs, while it's optional on non F Sports.
One projector = HID and two projectors = LED.
I too have been thinking about changing to Ultinon 6200k. They seem to be fairly priced from HIDPowerhouse. I've had good experiences with them and might try it.
I highly recommend you using this site. It will specifically tell you what size bulb you have etc. http://www.philipsautolighting.com/ajax_select.php
If you are interested in buying HIDs go to http://hidpowerhouse.com/
@DaJoDJ All you do is turn the metal cover counter-clockwise and put a bitt of pressure and it should pop right out no problem
