Rattle From Engine @ Startup
Old Jun 4, 2017 | 01:29 PM
DixieLex's Avatar
DixieLex
Default Rattle From Engine @ Startup
Quick, loud, and very noticeable.
What is it?
BTW, I know its not the click of the DI
Old Jun 4, 2017 | 03:53 PM
sktn77a's Avatar
sktn77a
If it's a 250, worn cam gears. Covered under the original powertrain warranty, otherwise about $2400.
Old Jun 5, 2017 | 09:56 AM
aduff415's Avatar
aduff415
I have this on my 2008 IS250, and the Lexus dealer said it could be the oil filter. I have yet to replace it, but will see if that fixes it. I doubt it could be the cam gears, as it doesn't happen all the time for my car. It generally happens on warm starts for some reason, rather than a cold start.
Old Jun 5, 2017 | 10:03 AM
sktn77a's Avatar
sktn77a
It's intermittent on my IS250 also but was diagnosed by the dealer as the worn cam gear issue. Can't imagine how an oil filter would cause this?
Old Jun 5, 2017 | 10:11 AM
aduff415's Avatar
aduff415
I doubt its a oil filer as well. Did you get your car fixed? and if so did the noise stop for you?
Old Jun 12, 2017 | 05:35 AM
DixieLex's Avatar
DixieLex
Default Still intermittent
It doesn't do it when its warm, only cold. Last for about a second, but its there
Old Jun 13, 2017 | 07:19 AM
jr4div2's Avatar
jr4div2
Reminds me of my dad's old MG where the oil pump was all gunked up or something like that. I was about 12 years old, but I distinctly remember hearing all the valves/cam clicking loudly right after a start-up and then it would silence down as the oil thinned. I remember he decided to rebuild the engine at that point so I don't know exactly, but if it's only a short-time after a cold start-up, then I would suspect oil flow being slowed and not coating the cam well until the oil coats them adequately. So it is possible the diagnosis of a sluggish oil filter could cause it. It's cheap enough. Change it and see.
RXGS
Sep 19, 2021 08:38 PM
terminater
Mar 19, 2018 07:53 PM
zinnerbug
Jun 23, 2016 04:30 AM
zinnerbug
May 22, 2015 03:58 PM
lexus-is2
Nov 4, 2013 12:06 PM
