GPS DVD stuck inside the drive
Hello,
in my IS250 from 2009 stuck navigation DVD during driving. I don't know if it's the bumpy road or a non-original DVD but it will not eject.
After starting the car I just only hear clicking from the drive. Tried to push/lift the disk with something plastic and narrow but nothing helped.
Is it possible to eject the disk without disassembling the whole unit? I can't do that so better not to touch it
. Does anyone have same problem: is that the non-original disk or possible drive fault?
BR,
Arthur
. Does anyone have same problem: is that the non-original disk or possible drive fault?BR,
Arthur
follow the video you good to go. 2 pin is in your toll set.
You don't have to use air suction just insert and pull out the panel
to eject the MAP data
1. press on menu
2. click on MAP DVD -top right conner
3. click on "eject"
1. press on menu
3. click on "eject"
Guys again: I DON'T HAVE ANY MAP DATA VISIBLE!
Black screen and the only thing is the notification "External system is not connected" and the DVD I BLOCKED
I've tried to lift it manually but I failed.
Any method to take it out without unit disassembly?
When you got message "external drive is not connected " means there is no power coming from the MAp UCE. It doesn't mean the DVD is stuck. If you have any work done lately required to remove the head unit, you may want to check the connection. I have seen those case already!!!
Trust me i won't. I did repaired a lot of Map ECU drive and know what the message mean.
If the problem causing by non OEM dics, you will see message "please insert the correct dics"
Good luck!
Good luck!
