Check System Light
Old Apr 24, 2017 | 07:06 PM
Anong's Avatar
Anong
Default Check System Light
Out of no where while driving my 2006 Lexus IS350, a Red Check System Light came on. Pulled over, no flat tire found. Went to get air 35/37 per spec. Red Check System Light remains on. Tried push the button under steering wheel to initialize tire pressure, tuned off engine. The Red Check System Light is still on.Please help! Thank you!
Anong
Old Apr 24, 2017 | 07:11 PM
ldc's Avatar
ldc
What other lights are on?
Old Apr 24, 2017 | 09:58 PM
XSV's Avatar
XSV
check engine light on? if so take it to autozone and get the codes pulled. If no check engine light on, take it to the dealership for diagnostic.
Old Apr 25, 2017 | 05:25 AM
Bichon's Avatar
Bichon
"Check system" is the TPMS error that comes up when it isn't getting a signal from the tire sensors, not when the pressure is wrong. Often that's because somebody played with the TPMS menu and accidentally selected the second set of tires, but since your car is over 10 years old, it's equally likely it's the batteries in one of the sensors. I'd call around and find a tire store that has a TPMS tool like the Bartec that can individually scan each sensor. If your sensors are original, they are definitely running on borrowed time, and all four should be replaced.
Old Apr 25, 2017 | 10:35 AM
mandyfig's Avatar
mandyfig
Ouch, all 4 should be replaced...how much each?
Old Apr 25, 2017 | 11:46 AM
Bichon's Avatar
Bichon
I'm not sure what the dealers charge. Looks like a Denso TPMS sensor for the '06 IS350 from Amazon is about $35.
Amazon Amazon
Old Apr 25, 2017 | 11:53 AM
XSV's Avatar
XSV
Don't go to the dealership. Bought used OEM ones off eBay for $80 shipped. They were already programmed for my 2008 Is 250.
http://www.ebay.com/itm/231430211513...%3AMEBIDX%3AIT
Old Apr 25, 2017 | 12:16 PM
Bichon's Avatar
Bichon
I'm afraid you are mistaken about thinking that they were already programmed, XSV. Each sensor has a unique serial number that needs to be programmed into the car. I am guessing that the tire shop did this for you when they mounted them on your rims. With the Bartec tool, it only takes a a minute or so to scan all four sensors, then plug into the OBD2 connector under the dash and upload them to the TPMS ECU. (even the eBay listing you linked mentions that they need to be programmed to the car)
Personally, I think I'd rather buy new ones. The sensors have a lithium battery that is only good for about 10 years, and if you buy used ones, you don't know how much battery life they have left.
Old Apr 25, 2017 | 12:54 PM
Tungstn-IS's Avatar
Tungstn-IS
That's what I was thinking, most of those ebay listing never specify what year they came out of. You could end up replacing 2006 sensors with ones from a 2007, which likely won't buy you much time.
matts6887
Jan 17, 2021 08:10 PM
EyeKutr
Jun 12, 2019 10:45 AM
Lexusgal06
Mar 3, 2018 09:50 AM
Danilo02
Nov 27, 2015 02:53 PM
mj250
Oct 1, 2012 01:16 PM
